Car smoking when letting out of boost
Old Jun 17, 2016 | 06:33 AM
dieselman88's Avatar
Default Car smoking when letting out of boost
I have a 98 Trans am, ls1 with a good ole on3 76mm turbo. Car runs good just noticed that it randomly throws blue smoke, oil, out the tail pipe but only when I come out of heavy boost pull about 10psi (tons of boost I know lol). It does have a oil restrictor in the oil feed line, since it has a high volume oil pump. I ran the drain line to the oil pan using one of the members on here set up, can't remember his name, and got rid of the scavenger pump. There is no flat spots in my drain line. Also has the stock ls1 pcv set up with a Norris catch can. Could my turbo be passing oil, or is my pcv set up not effiecent enough? I have to pull the intake here soon anyway and thought about switching to the ls6 pcv set up, I don't know if that would help anyway.
Old Jun 17, 2016 | 02:10 PM
forcd ind's Avatar
I ran the LS6 PCV system, it would suck oil into the intake-I installed an oil sep., it showed the oil getting in there, so I switched to a PCV valve in the valve cover.
Sometimes worn rings, guides can get oil in the cyls
Old Jun 17, 2016 | 03:58 PM
Dimeomboost's Avatar
Mine did the same thing same turbo but the 88mm same setup basically and until I used mighty mouse's diagram on crankcase pressure it smoked on decel at about 10psi
Old Jun 17, 2016 | 04:02 PM
Fat Jesus 808's Avatar
I made my drain bigger, and fixed this exact issue.
Old Jun 17, 2016 | 04:16 PM
It has a 10an line for a drain. Guess I can try switching my Norris can to a Mighty Mouse set up
Old Jun 17, 2016 | 05:32 PM
Is your catch can full? I have a decent breather system on mine and its not routed into the manifold.
Old Jun 17, 2016 | 06:13 PM
No it's not, I noticed the Mighty Mouse catch can has a filter on top where mine is sealed.
Old Jun 18, 2016 | 11:55 PM
94heritage's Avatar
I had the same issue until i vented the pcv and made a vent out of my oil fill cap. Did both of those vents problem fixed.
