Fuel Questions
Now I am putting on a huron v2 t4 kit with a BW s480 and the goal is to be around 650-700 to the ground. The car will be mainly a street car will weekend trips to the track. I have researched a fair amount on here but seems the fuel set up is something people skim over. I was leaning towards a drop in pump since I am budget minded. What would you all suggest? Also should I be running a return system or can a factory returnless system support that power reliably? What do you all think factory lsa 60# injectorys would be good to?
Any help is appreciated thanks guys!
- Single Walbro 450 in tank pump $105
- Siemens 80# injectors (Probably less than $100 after selling the LSA injectors)
- Magnafuel Boost referenced fuel pressure regulator (Around $200)
Boom. Less than $500 and you will have a pretty solid fuel system that can still utilize the factory feed and return lines. If you would like to upgrade to an 8AN steel braided feed line, by all means, go for it.
Thats the receipt right there. I made close to 800 on gas/meth with almost that exact setup (aeromtive regulator)
I did the swap, raised fuel pressure by 10 PSI and scaled my VE table accordingly. Now I constantly have issues above 16 PSI where the car sounds like its cutting out and losing power. Never had a single issue up to 28 PSI on the old setup.
I also added a brake booster which sounds like its hissing with boost.
