ati pulley ?
Old Jun 19, 2004 | 09:33 PM
Blown Ta's Avatar
Default ati pulley ?
what size pulley do i need to go from 5 psi to 7 psi.i have the 7 psi kit but i am only seeing about 5 psi.also would i need a retune or other fuel upgrades for this.right now i am running 38 lbs injectors.
thanks
Old Jun 19, 2004 | 10:47 PM
BlwnTA's Avatar
7 Second Club
What size pulley do you have now? You need to go down about .200"-.300". If your at 4.00 for example you need to pulley down to 3.8 or 3.7.
Old Jun 22, 2004 | 05:48 PM
Blown Ta's Avatar
my manual says i have a 3.40 7 pound pulley
Old Jun 22, 2004 | 07:42 PM
IRVINEWS6's Avatar
If I remember correctly, I have a 3.2 pulley, and I am only seeing about 5.5 psi.
Next week, I am going to order a SD Concepts 8-rib set up, so that should correct the low boost.
Old Jun 24, 2004 | 11:59 AM
snkchrmr's Avatar
I have a 3.2 on my p1 and I am seeing 7.5 to 8. Thats with 0 belt slip and a freshly cleaned filter.
Old Jun 24, 2004 | 12:04 PM
IRVINEWS6's Avatar
My combination of cam, heads, exhaust, and maybe some belt slip is probably why I only see only 5-5.5 psi.
Old Jun 24, 2004 | 03:09 PM
Blown Ta's Avatar
ok so it looks like i should try the 3.2 pulley for the p1sc
do you guys think i should get the computer re-tuned?
or maybe get 42 lbs injectors
because even now my fuel pressure drops to 55 psi,then goes back up to 60 when the transmission shifts
Old Jun 25, 2004 | 12:28 PM
snkchrmr's Avatar
Yes I would get injectors and tunning. You will also need a inline fuel pump if you don't already have one.
Yeah I would say with the heads and cam you would be down on some boost. Plus belt slip.
Old Jun 25, 2004 | 01:26 PM
WHPLASH's Avatar
I have the same setup as you. I had a 3.7 and saw 6lbs. Now I have a 3.5 and see 7.5 lbs. With a 3.2 you'd see 9-10 lbs.
Old Jun 25, 2004 | 05:26 PM
IRVINEWS6's Avatar
The difference is probably due to the difference between the D series and the P series prochargers.
