L92 and boost?
Old Sep 5, 2016 | 03:29 PM
ricardo.benin's Avatar
Default L92 and boost?
Hi I have a l92 6.2 that needs rebuild, so plan in forged rods and Pistons, but my question is this, what can the stock crank take power wise and what kind of fuel requirements will I need for say 800hp keep in mind I would like to do this with a single turbo in a 93 rx7.
Thanks
Old Sep 5, 2016 | 03:31 PM
Forgot to add that I want to do this with pump gas premium which I belive is 92-93 octane
Old Sep 5, 2016 | 04:09 PM
DavidBoren's Avatar
Stock crank will do fine for 800hp at the flywheel, probably 675rwhp. So would the stock rods and pistons, for that matter, as long as you have a good intercooler.
Other than that, dual 450lph pumps and 1000cc injectors. Probably use the good PTFE lines with -10 or -8 feed and -8 or -6 return, respectively, so you can use E85/93-mix if you have access to E85.
Might want to consider replacing the L92 intake with a LS3 intake, and the L92 valves with some LS3 hollow stem valves. New valve springs, lifters, pushrods, upgrade the trunions in the stock rockers, and get a turbo cam.
Old Sep 6, 2016 | 11:44 AM
Ok, I plan on getting a ls3 intake, will I need to get a fuel pressure regulator? Btw I can't belive stock rods and Pistons will hold that power. When I built my n/a l92 for my Yukon Denali I used Mahle and scar rods as I was told that 550 whp is to much on stock rods and Pistons?
Old Sep 6, 2016 | 11:46 AM
The closest e85 station is 30min away, I will use water meth injection. I also from what I understand that the stock Ecu will work for what I am doing.
Old Sep 6, 2016 | 12:02 PM
408GT's Avatar
I have an L92 in my car and have been 6.5's @ 112 weighing 3600 lbs. SBE w/ a JRF cam, car intake, S-480, E-85.
Old Sep 6, 2016 | 12:17 PM
JoeNova's Avatar
Restricted User
The gen 4 style rods in the L92 have been somewhere around 1400 HP.
The stock pistons can hang right along with them but they're picky on detonation/heat. The guys running methanol usually have no issues making the stock pistons last as long as the stock rods.
The crank usually gives out in the 1200-1400 range.
Chances are, the stock rotating assembly will outlast the block itself in a perfect scenario.
Old Sep 6, 2016 | 12:37 PM
JoeNova's Avatar
Restricted User
As a real-world check, tune has to be spot-on to make these live above 800whp.
It is becoming a lot more common to see them in the 800-1000whp range on a stock rotating assembly, but precautions are usually made to help them live. The ones living for 2+ years above 1000 HP aren't street cars either. You're talking drag cars, dyno queens, etc.
Old Sep 6, 2016 | 02:24 PM
oscs's Avatar
Stock steel valves are fine with the right spring setup. I use to rev my L92's to 7500 all the time.
Old Sep 7, 2016 | 10:03 PM
Wow, I had no clue they can handle that kind of power. I was told by a couple people that the powder rods can't handle that kind of power and that the piston ring lands are weak. Is there more stress on a n/a engine than a boosted setup? How do I use arp bolts on l92 rods since powder rods can not be reused?
Old Sep 7, 2016 | 10:09 PM
JoeNova's Avatar
Restricted User
N/A usually revs higher, has a bigger cam, etc. More stress in the valvetrain and some parts of rotating assembly.
Rod bolts are pointless if you keep the RPM down, since power doesn't effect them at all.
Old Sep 7, 2016 | 10:24 PM
Hmm ok, so is this power achievable on stock computer? Is the stock computer able to run a map sensor?
Old Sep 8, 2016 | 07:32 AM
JoeNova's Avatar
Restricted User
Your L92 has a MAP sensor already in the intake, so I would hope so.
I don't have much experience with the later gen 4 computers, but the stock Gen 3 is more than capable of insane numbers, so I would assume its fine.
Old Sep 8, 2016 | 09:25 PM
Ok, what will I need for t55 transmission?
Old Sep 9, 2016 | 10:01 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
People pop ring lands all the time. The reason is the stock ring gap only works up to a point before the rings butt ends, cracking the lands on the pistons. And yes, the rods will break before the crank, but that is still usually north of 800hp. As to the last point, stock rod bolts have held to the point of breaking stock rods on FI setups, so I think the point is moot. Turbos are MUCH easier on rod bolts than a high revving N/A setup.
Old Sep 12, 2016 | 12:23 AM
Cheese Weasel's Avatar
Yep - and I only learned AFTER I swapped my stock rod bolts for ARPs (in my last engine) that the stock rod bolts are actually pretty decent, meaning that I pissed away money/parts/time/effort that was completely unnecessary.
I'm hoping that maybe others can read this, & not repeat the mistake I made...
