Would I run into back pressure issues by switching to E85
. I made the switch from pump to e85 and love it the tuning window is larger and you just don't have to worry about octaine any more.
once the afr is dialed in your car should run a tenth or two faster then add a degree of timing and get a couple more.
made the swich this year and I don't regret it at all.
all that being said I think the benefits of e85 out weigh the downfalls of it . I have only been running it a year but cant see me going back . eather way build them and have fun.
I have not done an A to B backpressure test, but my setup spooled a bit better on E85.
Try it and see!
You can't think of exhaust flow on a turbo setup like a simple air flow model.
The exhaust flow characteristics will vary considerably based on boost, engine rpm, turbo rpm, afr's, ignition and cam timing, egt's, fuel type, etc.
An extreme example is how methanol fueled cars can spool HUGE turbos despite having much lower EGT's than a gasoline vehicle.
Pressure has a much greater effect on turbo spool up than heat alone.
Think of how banging the 2-step builds boost on the line much more effectively than using lean AFR's and no timing with high EGT's.
