600rwhp With Turbo
Old Sep 18, 2016 | 06:53 PM
ruru_17_'s Avatar
Default 600rwhp With Turbo
I wasn't sure where to post this so I'd like to start off by apologizing if it's in the wrong place.
So I have an LQ motor in a 1969 Chevelle. Not sure if it's a 4 or 9 but I plan on taking it apart and building it from the ground up. Can anyone point me in the right direction for what I need? I want it to be very streetable but still be very mean. Not worried about budget because you have to pay to play. What cam, heads, turbo, do I need to run to get what I'm going for?
Old Sep 18, 2016 | 07:05 PM
1bdbrd's Avatar
7665 or 7875 turbo, stock heads, stock intake (or ls1 intake) and basically any cam ever ground will make 600whp on a stock bottom end. Some will work better than others but don't over complicate it and it'll make the power you're looking for.
Old Sep 18, 2016 | 07:41 PM
ruru_17_'s Avatar
The engine has 317 heads and I believe a cam.. it sounds like it has a small cam but I'd still like to have the lope. What cam do you prefer? Swap heads?
Old Sep 18, 2016 | 08:49 PM
JoeNova's Avatar
Restricted User
7665 will have a hard time making 600 wheel on a cammed 6.0. Maybe a 4.8 or 5.3, but not a 6L.
Old Sep 18, 2016 | 08:50 PM
ruru_17_'s Avatar
I was gonna go with the 7875
Old Sep 19, 2016 | 05:56 AM
yenkomike's Avatar
if you have a stock engine you can put ls6 valve springs in it and run 10 to 12 lbs boost at it and it will make good power . we ran 11.36 in my brothers 4300# Silverado with a stock engine on 12# boost. ran it all year like that then he built a new engine and I put the old one in a truck I bought and drive it every day.
Old Sep 19, 2016 | 08:05 AM
RedRocketZ28's Avatar
No it won't. I made over 600 rwhp with an ON3 7665 at 14 lbs. on my LQ4.
The 7875 will get you to your goals and them some OP.
Old Sep 19, 2016 | 09:48 AM
ruru_17_'s Avatar
I was gonna go with the Tick Performance Stage 2 V2 turbo cam 231/231 .630/.605 115+5 LSA with the 7875, 317 heads and an LS1 intake.. is this a good combo? What about injectors and fuel pump?
Old Sep 19, 2016 | 11:09 AM
Area 51 Racing's Avatar
Sounds like a pretty solid setup. As for injectors, Deka 80s and go with a Walbro 450 or AEM 320. Keep it simple. And if you want to sell your 76/65, hit me up.
RyanR
Old Sep 19, 2016 | 11:15 AM
ruru_17_'s Avatar
RyanR
id love to sell you the 7665 but unfortunately I'm starting with a stock motor
Old Sep 19, 2016 | 11:33 AM
I'm rocking a T4 S475 on a stock gen 3 5.3 so I feel your pain man. But if you have a 05+ LQ4 or any year LQ9 it will take it and some. The 05 and up LQ4s received the upgraded, floating rods and all LQ9s are already updated. I seriously wouldn't be scared to hit 600whp as is or shoot for 750 once the the rings have been regapped and LS9 head gaskets installed.
RyanR
Old Sep 19, 2016 | 12:10 PM
ruru_17_'s Avatar
LS1 or Ls6 intake?
Old Sep 19, 2016 | 12:17 PM
****, I am on a stock bottom end Gen 3 LQ4 and just got my Fbody into the 5.9X's @ 119 mph. It's making some steam.
Old Sep 19, 2016 | 12:20 PM
If you're asking about your setup, LS6, TBSS, or even a stock truck if you have the room. Even though the stock LS1 should still work fine. I have a TBSS intake. Maybe someone else with some more experience with different intakes will chime in as I have zero experience with the car intakes.
And DAMN RedRocket, that's what I'm talking about big dog! STOMPING
RyanR
Old Sep 19, 2016 | 01:34 PM
ruru_17_'s Avatar
It has the truck intake on it still but I'd like to run an LS or TBSS
Old Sep 20, 2016 | 04:27 PM
91 240's Avatar
i made 608whp with my LQ4, 317 heads with valve job and springs only, Brutespeed 232/240 blower cam, old school MasterPower t76, 60lb injectors and LS6 intake at only 8psi
Old Sep 20, 2016 | 09:05 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
You maybe could hit your power goals without even opening a single bolt on the motor, but I would recommend valvesprings and pushrods. Since you now have a lot of extra free time NOT having to upgrade the rest of the motor, a good smoothing and paint job can make the stock truck intakes look pretty good. The difference in performance between it and every other possible intake you could buy at any cost will amount to less than 1 psi of boost at the power level you are aiming for. Most of the options will actually lose low end torque with no HP gain up top.
Old Sep 19, 2020 | 04:17 PM
Z32_5.3's Avatar
I have twins on a 5.3 gen3 making 700.
however my buddies setup is a single 78/75, 80lb dekas, springs,cam,450pump... made 550 very easy on pump gas. He had to change the AEM 3xx pump after 450 for some reason.
Old Sep 19, 2020 | 07:19 PM
jayyyw's Avatar
4 year thread bump
Old Sep 24, 2020 | 06:43 PM
Project GatTagO's Avatar
Originally Posted by jayyyw
4 year thread bump
It happens...
Andrew
