Huron v1 ac kit install, few issues and need ideas
PS, ditch that flimsy factory torque arm, your gonna have a turbo car! You sure did ditch the N2O idea in a hurry.
Ls1
Prc . Valve spring
Hardened pushrods
Ls7 lifters
Tsp camshAft
New timing set
Ls6 intake
60lb injectors
New oil pump
New timing set
Holley hp efi with digital screen and Holley meth injection.
Huron v1 turbo kit with 7868 turbo, cx racing intercooler, eboost street boost controller .
Ls7 clutch and flywheel
Bmr adjustable dom torque arm
Adjustable lower control arms
Adjustable pan hard bar
Front and rear sway bars
Subframe connectors
Toyo proxes tq drag radials
And a racetronic Hotwire kit 255lph with kenne bell boost a pump .
It's a solid start , and should be able to run a big t4 or ditch the kit "which is what I want to do" and go twins with a built tsp 408.
This winter it's getting a crp fab 9, tick performance level 5 tr6060, nasty n8 fuel system, and a mwc cage . I've got a good start , and plan to enjoy the car for a few months before winter comes if possible .. then turn it into a 1000 hp street beast over the winter months
The reason I mentioned the TA is because I ran my stock one for a long time after I did my heads/cam/intake mod. Occasionally there was a strange, but subtle vibration in the car on hard acceleration, I was thinking it was a bent axle or wheel, something like that. But hat didn't really make sense or it would be there all the time at speed right? I went to a weld in after market torque arm setup and the vibration went away. I believe it was the stock TA vibrating under load.
Contacting me direct for any questions I will always answer right away, opposed to having to run across a thread on here to help you.
For your fuel pump question with this kit, I would go with double pumper kit from Squash or Lonnies, however this does not match up with the set-up or goals you were discussing with me in email at all, so I am unsure which route you are taking here or set-up you are building to be able to best help you.
I see 2 builds here. One being the stock engine, V1 kit, 255 fuel pump and the other being a 408 with a custom twin kit, cage, fuel system, etc.
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
the unfinished project part-outs in the classifieds all have one thing in common, trying to build this year's car around next years parts.
