Lsa supercharger on l33 forged pistons 243 heads.
Building an l33 with 243 heads and forged pistons. Using stock gen4 floating rods with arp bolts. Going to ru as much booat as it likes with the lsa blower... whats thexbest compression ratio to aim for on 91pump gas no meth. I can mill heads to get 9.0 maybe more to get 9.5 what does everyone think is best compression ratio?
Pistons will be wiseco k0042x1 or je 315554 both about same price. Not sure whats a better piston? Sure both are good...
Came up with another option... ljms 3.800bore -2.2cc wiseco flat tops. If i use them i need the 6.125 rods and wouldn't have to mill heads any. Should be around 9:6 cr. Was trying to save some $ because my l33 has gen4 rods they should be fine for what im doing. But after arps and resize might not be saving much... also would save on machine work on milling heads, just deck them and slap them on....whats advantages to 6.125 rods over stock legnth? Some people ask why forged pistons for only 15psi or so? I got l33 for nothing but it has no heads and needs a rebuild (was low on oil psi) so planed on little bore and new bearings.. didn't think worth using stock pistons at this point...
