2 bar map sensor issues
Old Nov 19, 2016 | 02:57 AM
Dennis5374's Avatar
Default 2 bar map sensor issues
I have a turbo ls1, running Holley hp efi. Initial setup , the 2 bar cobalt "baro" sensor, read 99kpa koeo, in the last few days, I've noticed my eboost street was not reading vacuum at idle, and instead was showing 1.5-2 psi boost! Even in my datalog I wasn't exceeding 5-6 psi "about 137-141 kPa. This is with a 8 lb spring in my gate . Needless to say I decided to see what the map sensor read with koeo, and it showed 89kpa!!! Is this what's causing such a high reading at idle, as well as not showing early as much boost as I'm truly making ? I think the map is lying and causing a much lower kPa reading in the log, but as I'm new to this, I just wanna be sure before i go throwing parts around
Old Nov 19, 2016 | 06:26 AM
03sierraslt's Avatar
Moderator
KOEO the map sensor should read outside pressure. Whats your elevation?
Old Nov 19, 2016 | 07:53 AM
Dennis5374's Avatar
240 foot. Before I blew my turbo it read 99 kPa, it now reads 89
Old Nov 19, 2016 | 07:55 PM
RealQuick's Avatar
So what does it read with the key on (engine off)?
Old Nov 19, 2016 | 07:56 PM
RealQuick's Avatar
NM, just saw, 89kpa definitely not right... Should be 99-101kpa.
Old Nov 23, 2016 | 08:09 AM
Dennis5374's Avatar
It sorted itself out after i changed the cc routingn and breathers around . She's now happy at mid 170s kPa full on , no knock and screaming ! I pulled some fuel up top out of the base table, and it's been a monster up until the massive snow storm we got Monday/Tuesday. Now it's parked in the garage till April
Old Nov 23, 2016 | 08:50 AM
RealQuick's Avatar
did you sort out the koeo reading?
Old Nov 23, 2016 | 01:32 PM
Dennis5374's Avatar
Yeah 99 , idk if the Holley ecu had a moment the day I datalogged it but now it's reading perfect
Old Nov 23, 2016 | 04:16 PM
RealQuick's Avatar
Nice!
Old Nov 26, 2016 | 10:53 PM
customblackbird's Avatar
Just a heads up... pretty sure the cobalt sensor is a 2.5 bar. You might want to confirm that. GM sells an actual 2 bar sensor thats different and its what I run (says it right on the sensor).
Old Nov 27, 2016 | 03:11 AM
Dennis5374's Avatar
It's a cobalt baro sensor , which is 2 bar.
