Anyone using a single BW S369SXE ?!
Old Oct 18, 2017 | 11:49 AM
  #81
SLOW SEDAN's Avatar
Originally Posted by LSOHOLIC
Seems Nathan Shaw bolted a set (S369SXE) on his Nova. Hasn't posted results but says they feel great. This should provide some insight and valuable data as compared to his TC 72 cast wheel/68 turbine combo....car went something like 7.9x @ 172.
With a combo that sorted out...the results of the new turbos should validate the findings.
Good stuff, what size engine?
As mentioned the smaller engnes run at a much higher pressure ratio on the map where the s369 really shines. Most arent going to run 40-80+ lbs of boost like the small engine guys do. Not thT u cant make great power w them, but they arent going to perform like they do on small engines
They seem to work fine at low boost as well, I went faster with them on wastegate (15PSI) then my single setup on 27+PSI. 15PSI is in the meat of the efficiency zone, two of them on low boost are flowing what a popular S476 or S480 does maxed out which seems ok to me. Especially for the price since two of these were cheaper then a billet S480. Unfortunately I dropped a lifter before I could turn them up... now that its back together should make some jams on more boost.
Old Oct 18, 2017 | 01:10 PM
  #82
LSOHOLIC's Avatar
Alum 5.3....here is the build..
https://ls1tech.com/forums/forced-in...quest-7-s.html
Old Oct 18, 2017 | 01:30 PM
  #83
SLOW SEDAN's Avatar
That's awesome! I'll have to keep tabs on that one for updates.
Old Oct 30, 2017 | 10:59 AM
  #84
SLOW SEDAN's Avatar
Originally Posted by GrannySShifting
Any more experience with the 369sxe in a twin config?
These things are killer on a 3.0 2jz, not sure why they wouldnt be with 2 on a 6.0???
So far so good, I think they would be better on a larger engine instead of my 5.3L but its what I have. Not the greatest 60' and a slow boost ramp but still went 5.9@121 in the 1/8 on under 20PSI, 9.1@152 to the 1/4 so they seem to work well even when they aren't turned up. Had pitiful timing in it as well since it was just a shakedown pass, plugs look good so its getting turnt next time out. I don't see a reason to doubt the S369SXE performance, they seem to respond well.
Old Oct 30, 2017 | 12:04 PM
  #85
3 window's Avatar
Gimme some more info on the car. Weight, gear, engine, slicks or radials, etc.
Old Oct 30, 2017 | 12:05 PM
  #86
3 window's Avatar
Old Oct 30, 2017 | 12:14 PM
  #87
SLOW SEDAN's Avatar
5.3L in a family car, 28” Hoosier, 3.45 gear.
Old Oct 30, 2017 | 01:28 PM
  #88
Forcefed86's Avatar
That's cookin! Should be even more efficient at higher boost levels.
It's more than just the boost level it's the pressure ratio.The PR is generally higher on a smaller engine at the same power level as a larger engine. Smaller engine may be a good thing with those particular units. Should get them into a more efficient range.
Old Oct 31, 2017 | 02:58 PM
  #89
cosbysweater's Avatar
While I don't have any experience with the 369sxe, I will say I have a lq4 with a 80e, and a s366 with stock Z06 valve springs and a Z06 cam, I love it for a daily. It lights off extremely fast, I will say over 5k you can feel it start to nose over a little bit. However it all really depends on your end goal. I hope to swap in my billet s369 at some point but as of right now I really like the way it works. Perfect for a daily
Old Nov 1, 2017 | 06:21 AM
  #90
94heritage's Avatar
I would say the laying over would be due to using the z06 cam. The standard 66 s300s have made great power on a single.
Old Nov 1, 2017 | 11:26 AM
  #91
Turbo D's Avatar
I'm switching from twin China 72/68's to sxe369's this winter, That is pretty much the only thing I'm changing so I should have some pretty good back to back data. Went 8.5@155 on 25lbs on the China's
Old Nov 1, 2017 | 01:30 PM
  #92
TT427's Avatar
So how much is an s369 SXE? I see some 1 saying 2 for cost of an s480, I don't recall the SXE being cheap when I was looking... Also how does it compare to a TC78 In size/weight, power and response? TC78 was the other turbo I was looking at fir a stock ls1 6spd but ended up with an on3 billet 84 for future upgrades and auto.
Old Nov 1, 2017 | 02:06 PM
  #93
SLOW SEDAN's Avatar
In my case I got them for $625 each so I couldn't turn them down for that price, I think normally they are closer to $750-800. But even so a billet S480 is north of $1500.
I had the on3 84/75 before switching to twins, worked ok but couldn't make the jams I was looking for. It worked better then the 78/75 as far as holding more boost up top.
Looking forward to the results! Its already quick will be a good comparison.
I'll see how it responds with more boost, we have another track day planned.
Old Nov 1, 2017 | 03:31 PM
  #94
TT427's Avatar
Hmm, sounds right, I remember seeing them in the 800 plus range for the super core plus 150-175 for the housing. I would do a GT91 for less than the price of a billet s480 myself. I think the Borg gets pushed too much based off the cheap units... Cost vs performance seems moot on that higher flowing large frame stuff IMO.
Old Nov 1, 2017 | 03:55 PM
  #95
SLOW SEDAN's Avatar
GT91 doesn't make any more power then an S476 and its still close to $1500. The modified Borgs work pretty well but with the price closing in on $2400 might as well get a PT106 or something ridiculous for that price.
Old Nov 2, 2017 | 11:12 AM
  #96
TT427's Avatar
ya I was just going off if forced induction s site, for 1395 the GT91 is rated higher than anything else I could find with similar specs/frame size, as far as I know they had 1 of the best billet 80 wheels? Direct comparisons are hard to find due to similarities I guess?
Old Nov 18, 2017 | 09:13 PM
  #97
SLOW SEDAN's Avatar
Hopefully you’ll be pleasantly rewarded! Ran mine again on slightly higher boost and went high 8’s @ 158+ on 24-25lbs with the 369’s with a horrible 60’ because track wouldn’t hold a launch. That’s on a 5.3 with stock 862’s which probably choke the boost a bit. I can see these being really efficient on a better engine.
Old Jan 6, 2018 | 06:36 AM
  #98
Bluchevypick's Avatar
12 Second Truck Club
Ive got a S369SXE on my LS2 in my AWD TBSS and it shines very well for a daily. Maxes out my 82lb injectors with methanol on 13 lbs of boost. I am a dealer for Borg Warner also and can sell the S369SXE with a 1.0 divided exhaust housing for 815 plus shipping.
Old Jan 6, 2018 | 08:03 PM
  #99
slowlsx's Avatar
Instead of getting a s369 which has a tiny 73mm turbine I have a damn near brand new forced induction billet s472 with 83mm turbine and 1.10AR T6. Spoiled very fast in a 5.3 I will give you a great deal!
Old Jan 7, 2018 | 11:25 AM
  #100
zblee's Avatar
Me. I have a 5.3 with single 369. In warm weather it dynoed 600rwhp on 12 psi. Trapped around 116/117 in the 1/4 at 4800lbs . Now that it’s cooler it traps over 122 at the same weight . So I think it’s closer to 650+ now. I would imagine the 6.0 and more psi could hit 800
Zblee
