Anyone using a single BW S369SXE ?!
Old Dec 10, 2016 | 02:45 PM
1999Firehawkls7's Avatar
Default Anyone using a single BW S369SXE ?!
A company is telling me I can hit 800whp w a single 369sxe on my stock stroke 6.0 at around 15-16psi w this turbo.....
Someone needs to make me a believer!
Wanting a fun Single Turbo w a little room to grow but still spools up relatively quickly so it's fun on the street yet still hauls tail at the track.
Wanna stay w the BW line Turbo's
Car is est 3,200lbs
Stock Iron 6.0 Block
Stock Crank
Wiseco flat tops
K1 Rods
317s unported
4l80e
Old Dec 10, 2016 | 03:10 PM
Project GatTagO's Avatar
I don't know that I believe that. It would be a torque monster butt will run out of steam by 5500RPM...
http://www.turbos.bwauto.com//afterm...6_wrsin=92044&
Old Dec 10, 2016 | 03:16 PM
Ya I wanna shift at 6800-7000 max
Old Dec 10, 2016 | 04:08 PM
What turbo should I go w than?
Old Dec 10, 2016 | 05:28 PM
Click the link I posted and use the match bot. There are links at the bottom you videos that explain it.
Andrew
Old Dec 10, 2016 | 06:11 PM
Thanks!
Old Dec 10, 2016 | 08:23 PM
DavidBoren's Avatar
I think the S366 and S369sxe are both best used as twins.
If you want a single turbo, I would look for something larger, personally. S480, or something like that.
The S369sxe is awesome as a single unit on smaller engines, they can make 39psi and 850rwhp on 3.0L 2JZ motors... so think about what two of them can do on a 6.0L LS motor.
Old Dec 10, 2016 | 08:59 PM
Right I won't say the company's name but I had the same thoughts.... I've rode in a 88mm Supra before at 650whp in low and it spooled it just fine
Old Dec 11, 2016 | 01:52 PM
Here is some inspiration...
https://ls1tech.com/forums/conversio...hp-17-psi.html
Andrew
Old Dec 11, 2016 | 01:59 PM
Here is build that is about to use the S369SXE on a 5.3L...I am eager to see results.
https://ls1tech.com/forums/conversio...ed-swap-7.html
Andrew
Old Dec 11, 2016 | 02:58 PM
Here is a video that I ran across...
Andrew
Old Dec 11, 2016 | 05:31 PM
rotary1307cc's Avatar
It's a hell of a lot better match than the tc76 junk everyone puts on
Old Dec 11, 2016 | 07:44 PM
icicleboy's Avatar
That Cartuning GXP is my kit. that power is through a 4T65E auto on a completely stock 5.3 with DOD lifters/cam and all. that would be north of 600 on an manual trans. tiny 2.5" downpipe.
Old Dec 12, 2016 | 05:59 AM
alocker's Avatar
The compressor appears to flow enough to meet those goals. I think with the largest turbine side you could do it depending on the dyno. I think the combo will be more fun if you stay conservative and I suspect a lot of overturboing going on out there. For sure you don't need to wind it to 6800 RPM. I shift at 6200 and feel no need to wind it any higher.
Old Dec 12, 2016 | 06:53 AM
svslow's Avatar
100% true
Old Dec 12, 2016 | 07:03 AM
JoeNova's Avatar
Restricted User
It might make 800whp on a properly setup 4.8.
Depending on camshaft, I think it'll struggle up top on a 6.0 trying to hit 800whp.
Old Dec 12, 2016 | 07:40 AM
hellbents10's Avatar
LS1Tech Sponsor
I had a hard time with one over 550rwhp on a 5.3. It would not make more then 12psi or so.
Old Dec 12, 2016 | 07:51 AM
svslow's Avatar
Any info on the cam for that set up?
Old Dec 12, 2016 | 07:56 AM
JoeNova's Avatar
Restricted User
Damn, that's rough. I did a 68mm ebay GT45 setup for someone on a small cam 5.3 that made slightly more than that on a Mustang Dyno.
Old Dec 12, 2016 | 08:03 AM
svslow's Avatar
The BW has to have a much more efficient compressor/turbine than the 7665 units that everyone uses. I would have thought it would make more.
