Borg Warner turbo size
If I had to do it again I would go straight to the t6 flange. I don't want to have to do it over again when it comes time for a new motor!
With a few kinks removed I'll be curious to see where this "little" turbo takes the car in the future.
Thats ridiculous. I've run the small S475 (83/74 Wheel) and the big 87/96 wheel in the same T4 housing (1.10 first then 1.25AR) then a T6 1.32 housing. The larger I went in housing size and exhaust wheel size the more power I made. Every time. Response was very similar across the board. (assuming you have the hotside setup correctly) Having tried them all I can tell you I'd never bother with anything less than a T6 or the 87/96 exh. wheel. on a Small block anything. The power made per pound of boost just isn't there with the smaller units... even on 4.8 and 5.3 liters. I'll take real world experience over a matchbot anyday.
I'd go to turbodaves.com to grab the $640 shipped T6 1/32 S475. Or VSracing to get the T6 1.32 billet S480 clone. Run a 2" hoside feeding both sides fo the scroll on stock manifolds. It will spool plenty fast and make 1000 crank hp turned up.
