another turbo ls notch build
Old Feb 12, 2017 | 06:03 PM
trboman's Avatar
Default another turbo ls notch build
A few pics of my 93 notch, I waited a couple years to find this one and yes it actually was grandma's car. I bought it with 86,000 kms from the original owners daughter. This is my first post, however I have been lurking for some time now getting ideas from others on this site.
The build has been underway for awhile now. I will post some pics to catch up to the builds current state. I can't take credit for all custom fabrication, I have a local shop with amazing skills and knowledge performing a lot of the work.
Attached Thumbnails another turbo ls notch build-notch-build-003.jpg   another turbo ls notch build-notch-build-005.jpg   another turbo ls notch build-notch-build-024.jpg   another turbo ls notch build-notch-build-007.jpg
Old Feb 12, 2017 | 06:10 PM
rkupon1's Avatar
Great Project-from scratch. In for the build...
Old Feb 12, 2017 | 06:40 PM
trboman's Avatar
The 2.3 coming out.
Attached Thumbnails another turbo ls notch build-notch-build-084.jpg   another turbo ls notch build-notch-build-085.jpg
Old Feb 12, 2017 | 06:51 PM
trboman's Avatar
I am using an AJE kmember with stock front 4cy springs, stock V8 struts, spindles and brakes up front. I have also shaved the front sway bar mounts off the rails to clean it up a little.
Attached Thumbnails another turbo ls notch build-notch-build-020.jpg   another turbo ls notch build-notch-build-019.jpg   another turbo ls notch build-notch-build-088.jpg   another turbo ls notch build-notch-build-089.jpg   another turbo ls notch build-notch-build-090.jpg
Old Feb 12, 2017 | 07:05 PM
trboman's Avatar
Battery disconnect installed as well as a secret momentary push button under my ashtray lid.
Attached Thumbnails another turbo ls notch build-notch-build-045.jpg   another turbo ls notch build-notch-build-046.jpg   another turbo ls notch build-notch-build-061.jpg   another turbo ls notch build-notch-build-067.jpg
Old Feb 13, 2017 | 09:44 AM
Gunters96lt1's Avatar
Wow this notch is clean!!!!
Old Feb 13, 2017 | 05:18 PM
trboman's Avatar
some more progress pics. I have chosen to go with a simple well proven combo based on all the reading I have done. JY LQ4 with a th400 and an S475 along with 33 spline spool and 3.27 gears. Why not gently roll the fender lips just in case.
Attached Thumbnails another turbo ls notch build-notch-build-159.jpg   another turbo ls notch build-notch-build-044.jpg   another turbo ls notch build-notch-build-021.jpg   another turbo ls notch build-notch-build-071.jpg
Old Feb 13, 2017 | 05:26 PM
trboman's Avatar
I will only have one aftermarket gauge in the car, this is a street car after all. Microsquirt will be taking control.
Attached Thumbnails another turbo ls notch build-notch-build-039.jpg   another turbo ls notch build-notch-build-055.jpg   another turbo ls notch build-notch-build-064.jpg   another turbo ls notch build-notch-build-081.jpg
Old Feb 13, 2017 | 09:03 PM
Forcefed86's Avatar
In for progress...
You can clip that shroud and glass it in so you have full radiator coverage as well. I used cardboard and just glass over it on both sides. Done several that way now with the taurus fans.
Attached Thumbnails another turbo ls notch build-20160530_132259_zpsagxgwppq.jpg
Old Feb 13, 2017 | 09:41 PM
trboman's Avatar
In for progress...
It definitely looks more finished with the work you have done to the shroud. I am planning to have my turbo close to the rad fins on the uncovered portion. This build is getting a/c as well, so I have the 4" ic and condenser stuffed in front of the rad, space is limited
Attached Thumbnails another turbo ls notch build-notch-build-120.jpg   another turbo ls notch build-notch-build-118.jpg
