Making the switch.... rear mount to front mount turbo.
Old 12-24-2020, 03:02 PM
  #141
rel3rd's Avatar
I'm sure you'll have to tweak the PT settings. I have a 4L80e, which has different ratios in 1st and 2nd gear, than a 4L60e.
Glad to help.
The following users liked this post:
JoshuaGrooms83 (12-24-2020)
Old 05-13-2022, 02:02 PM
  #142
JoshuaGrooms83's Avatar
I know it's been a minute. Was gone on deployment last year.
after my booboo with the stock radiator, griffin radiator install was the only way lol
Got a little cleaning up to do, but almost there. need to make some brackets, trying to clean up the wiring, and looking to seeing how i can get the coolant sensor in place.
rel3rd (05-13-2022)
Old 05-13-2022, 02:08 PM
  #143
rel3rd's Avatar
Awesome man. I've been going round and round about doing a stand up rad on mine, so I can swap on a bigger turbo.
Care to share any part numbers and/or tips?
Most of the info available is either picture-less, detail-less, or outdated.
Looking good though.. 👍
JoshuaGrooms83 (05-14-2022)
Old 05-14-2022, 09:05 PM
  #144
not a problem! yeah that was partly what I was thinking too. alot of data is getting old or pictures are getting corrupted. I wish they made uploading videos easier too directly from mobile devices.
I followed most of this post, and nearly all of it worked.
https://ls1tech.com/forums/forced-in...ow-part-s.html
I'll have to go back over the parts that I added for numbers or where I got them. like the lower hose, and upper hose insert for the steam vent.
Also, if you're an auto, take into account your cooler lines. removed a portion that connected to the stock radiator and clamped it temporary back to existing line stock lines. I'm going to install an lines later once I get the car home.
Old 05-14-2022, 09:20 PM
  #145
Here's a cold start and leak check on initial start up
Quick Reply: Making the switch.... rear mount to front mount turbo.
