Basic setup, how much boost??
Old Feb 20, 2017 | 05:58 PM
fbody4everyone's Avatar
Default Basic setup, how much boost??
throwing on a t76 turbo kit here soon on my stock bottom end ls1. untouched 799s, gm hotcam, stock ls6 intake, 255pump with hotwire kit, other supporting mods etc, 400rwhp
dont care for dyno numbers, id just like it to be safe/conservative and a little more fun to drive.
but since the cam is small and my heads are just stock 799s, should i plan on the heads and cam to help at all? or is it pretty much going to act as a stock ls1? because i see people running 8lbs on full stock ls1 hitting 500-550hp. reason is, my fuel system noted above, says it holds up to 550-600 depending on setup. wouldnt wanna hear from my tuner that im leaning out up top.
**What do you guys recommend for a wastegate spring to be worth my while?? ill get a boost controller if needed.
2 hour drive on trailer to my closest tuner, wouldn't wanna make 2 trips for a simple problem, what do you guys think?
thanks!
Old Feb 20, 2017 | 06:25 PM
Prowler's Avatar
8lbs of boost be like having a 125 shot all the time.
Old Feb 20, 2017 | 06:36 PM
truckdoug's Avatar
a properly set up manual boost controller will serve you really well. you can go from the lightest spring you have to nearly pinning the gate shut if thats what you want
what injectors do you have? a single 225 is really working out at 550 wheel. my buddy's car would go really lean after that on a single 225, 3/8 feed, 5/16 return.
Old Feb 20, 2017 | 06:43 PM
ill be buying 60lb injectors at minimum. its the 255 racetronix, with hotwire kit. what kind of power is he making before he leans out? maybe a 6 or 7 lb spring with controller?
Old Feb 20, 2017 | 07:04 PM
ScottyBG's Avatar
I'd just buy the 80 lb injectors they are about the same price. I think I paid $5 more for 80s vs 60s. I would estimate you will run out of fuel pump about 6-7 psi on your combo with a 255 pump. That should make you about 500-550 through an auto or close to 600 rwhp with a stick. Depends on the dyno and a few other variables.
Old Feb 20, 2017 | 07:09 PM
it is a 6 speed. ill look into getting 80# injectors for sure if thats the case. and you rlly think thatd put me that high?? thatd be nuts. maybe a 6 lb spring with controller then.... hmm
Old Feb 20, 2017 | 07:55 PM
ScottyBG's Avatar
On my setup, similar to yours, I have a little bigger cam and ported heads, but not dramatically different, every lb of boost was worth about 25 hp, on an unlocked auto. You may gain a little more on a stick because there is less loss, but my turbo is probably a little more efficient to negate that. So add 150-175 hp (for 6-7 lbs) to your stated 400, and that's about where you should be, and doing the math, that's about all a 255lph pump will put out fuel wise. These are round numbers because our cars are not exact, but should be reasonably close.
Old Feb 20, 2017 | 07:56 PM
truckdoug's Avatar
haha mark my words you will be swapping in a 450 pump about 5 minutes after getting 600 wheel
Old Feb 20, 2017 | 08:00 PM
that sounds pretty good to me. hopefully i can keep it from going lean
Old Feb 20, 2017 | 08:02 PM
i really dont think ill go that high, low to mid 5s would be fine lol. getting to 600 would be too much stress on my setup id assume
Old Feb 21, 2017 | 04:29 PM
anyone else throw in a guesstimate?
Old Feb 21, 2017 | 06:30 PM
SethU's Avatar
thanks!
Isn't the obvious answer, to buy and bring all the available springs as well as a MBC and any needed install parts to your tuning session?
Old Feb 21, 2017 | 06:50 PM
truckdoug's Avatar
bring snacks. everybody loves a bag of chips.
Old Feb 21, 2017 | 06:54 PM
will definently need snacks to watch her blow
Old Feb 21, 2017 | 07:00 PM
truckdoug's Avatar
people underestimate the snack level needed for a dyno sesh. cant be all hangry at the dyno.
Old Feb 21, 2017 | 07:13 PM
ill prob bring a snickers, 6 or 7 lb spring and boost controller
