Dyno graph inside Why is my boost falling off on the big end?
Edit...it should be even worse on my car cause its a blower which will generate more pressure at idle than the turbo since its RPM dependent.
Yes.... It can... Mine does
Crack the bov and air is leaving the port to atmosphere, Not entering the charge pipe
I have a ball bearing turbo, and that may also be part of why I see as much as I do even at an idle. Before I put my turbo on the car I could spin it just by blowing into the turbine housing. Going back to my original statement(see post #22), I'm not saying there is a large amount of boost here at an idle, just that it is not in vacuum, and that it doesn't suck on the piston seal on the wastegate like hooking your wastegate up to the manifold does. There are multiple references to this out there by Tial, JGS and PTE that state this. This is not something I came up with, it is documented by the wastegate manufacturers in their installation instructions etc.
A ruler, couple zip ties, some aquarium air line, a little water, and you're there. The plastic tubing might even fit on an existing barbed nipple if there's one in your system pre throttle plate.
yes !
Air generally moves because of a pressure difference. the Bypass hangs open and the air comes out- therefore there is higher pressure inside the plumbing than outside it. It might only be 0.1psi higher, but it is higher. To measure this you would probably want a gauge that reads in inches of water above atmospheric- and log it via the computer- the same sort of measurement gauge I use to measure vacuum below atmospheric (in inches of water) in a crank case during boost, to prove the compressor is actually providing PCV action to the crankcase via the compressor inlet if possible.
What is happening as the blades of a fan type device turns? Air molecules, gas molecules, are physical things, just very tiny and transparent to us. The fan blade swings around, through them, pushing them together, gathering them at certain places, perhaps near the tips of the blades or otherwise, creating a pressure difference from one side of the blade to the other thus causing them to move with more purpose in a specific direction and with greater velocity and closer together, as others move in to fill the gaps where previous molecules used to be. Why do new molecules seek to enter the space where previous molecules existed, before those were scooped away? It is entropy, the desire for air molecules to seek the ends of their containers and spread with a speed and distance between them depending on their temperature and pressure, to the full volume of their container.
So yes, the pressure is lower above the blades of your ceiling fan when it is turning a certain direction, and something about airplane wings and lift should also be going through your minds as well, for it is the same sort of magic at work there as well.
Have you seen the size the hole it takes to allow enough air to idle an engine? Its tiny.
Have you ever spun a turbo by hand? it moves enough to feel.
Dont be retards. its def positive pressure. Where you try to measure that is a different story.
Keep you BOV shut, stick a MAP on the charge pipe and idle the car. It will be positive.
This is both an economy feature and performance feature; it is how a factory bypass is generally setup on OEM turbo cars. It allows compressor wheel speed maintenance during throttle lift events, and through them, provides a pressure increase in the space between the compressor inlet and air filter.
If you think of the reverse: imagine you clog the air filter, what happens to the pressure just behind the filter, pre turbo? The pressure will drop in this area, you will have a vacuum when compared to atmosphere. The more you clog/cover the air filter, the lower the pressure will go behind the filter, the fewer air molecules will be available in that space to breath.
