Dyno graph inside Why is my boost falling off on the big end?
But seriously that is a reasonable number for that setup. I agree the cam is fine. You should use the boost line off the compressor housing to control the wastegate. A wastegate should never be controlled off the manifold. A wastegate shouldn't vacuum, only boost. Vacuum is not good for the seal on the piston on the wastegate. It should be held closed by the spring, or pressure on the back side of the piston, and pushed open by boost on the underside of the piston. That is from reading the instructions that came with one of my wastegates said anyhow. There is a reason why compressor housings are drilled and tapped here.
You should compensate for your pressure drop through the inlet piping, the intercooler and the throttle body. For example I have my gate set at 16.5 PSI and I data log 15 PSI on the MAP sensor. Thus I loose 1.5 PSI in my system, this is a very normal number considering my setup. My boost is flatlined, well within 1 PSI from 4000 through 7000 rpm, and I only use a spring, no controller.
Benita!! Benita!!
Benita, haha
this is exactly how it's hooked up
8 psi spring 44mm xspower wastegate
. That should 'splain it. Forgiveness not permission. If I didn't go that way, I probably be driving a Taurus, and not a new SHO, probably something like a '96 bubble mobile. No disrespect to my wife she is a great person, but people only behave the way you let them. Show her you have a
.Oh yeah, and tell her you have a Benita, and you need another one. Actually scratch that, don't tell her anything about Benita, that could get you in more trouble than building a motor.
I think using the setup on page 10 will give you better boost control. How big of a spring do you have in your gate? I'd put about a 10psi spring in it.
8 psi spring as stated above also
