Dyno graph inside Why is my boost falling off on the big end?
Now add a second intercooler and a second infinite supply of 40ºF water and run it again.
Is the post intercooler charge temperature the same or cooler?
Is the post intercooler charge pressure higher or lower?
According to the physics book, when a thermal equilibrium is established, heat is neither gained nor lost by the system to it's surroundings. So what is the air temperature differential along the path, and at what point does it, if ever, achieve a thermal equilibrium? Is the answer to your question. Am I allowed to ask you a question now?
Ambient temperature is 70ºF and we're at sea level
We're pushing 20 psig and the compressor efficiency is 60%.
Using the delta of the resultant pre-intercooler charge temp and the 40ºF intercooler water to calculate the single intercooler efficiency, results in 85% efficiency.
Need anything else?
I will fabricate some data that you have not provided.
If the size of the engine is 5.7L, the RPM is 6000, volumetric efficiency is 100%, adiabatic efficiency is 100%, then the flow rate at 20psi is 616CFM*2.37 = 1459CFM
Now we know that there is a turbocharger which flows approx 120lb/min installed, given the engine size is 5.7L which you never mentioned, it could have been a 2.0L engine or 1.0L engine or 15L engine for all I know, which affects flow rate, and thus intercooler capacity.
Now knowing that we are dealing with ~100lb/min or approx 1500CFM of airflow, we look at the intercooler size which you also failed to mention the volume. If the volume of such an intercooler were, say, .00005L, then it would do nothing to cool the air. If the volume were 9999999999L (approaching infinity) then it would gobble all the air up and nothing would ever come out the other side to feed the engine. So let us assume an intercooler volume of X, this will be our variable. If I assume we have 20psi prior to the intercooler, and 19PSI after the intercooler,The 20psi figure you quoted must be measured at the compressor outlet, which you also fail to mention where it was being measured from.
All of this missing data is making me fabricate/assume quite a bit.
Here is an equation for finding the air temp coming off the compressor
http://www.gnttype.org/techarea/turbo/turboflow.html
The data closely resembles our situation, the outlet temp is around 250*F.
So now we can extrapolate the starting and ending temperature of the air as it passes through an intercooler with a volume of X,
Air temperature before and after an intercooler volume of X, with a reservoir temperature of 40*F and infinite heat capacity (it never goes up to 41*F no matter how much thermal energy it absorbs)
Inlet air temperature is 250*F, using an exponential or logarithmic scale for our single constant to condense the information here (as when the number "5" is approaching infinity, and X+1 is a "perfect size intercooler") for X is negative 5 to positive 4:
Outlet temperature when volume is X-5 = 250*F
Outlet temperature when volume is X-4 = 240*F
Outlet temperature when volume is X-3 = 220*F
Outlet temperature when volume is X-2 = 180*F
Outlet temperature when volume is X-1 = 120*F
Outlet temperature when volume is X-0 = 80*F
Outlet temperature when volume is X+1 = 40*F
Outlet temperature when volume is X+2 = 40*F
Outlet temperature when volume is X+3 = 40*F
Outlet temperature when volume is X+4 = 40*F
As you might have guessed, once a certain volume of intercooler is installed, the air temp can go no lower than its reservoirs thermal equivalent, as the physics book example I posted above, heat will no longer leave or enter the system once a thermal equilibrium is established. You can install as many intercoolers as you like after X+1 and it will make no difference to the temperature. Pressure, on the other hand, will continue to drop, as long as you are adding plumbing volume, it doesn't matter if the plumbing is an intercooler or a straight pipe; the volume itself is responsible for carrying the additional weight of air molecules which require additional effort on behalf of the engine or compressor, thus lowering pressure.
My question is a beginners calculus 2 question involving infinite series, since you are having trouble grasping at infinity I thought it appropriate to show how we can work with an infinity symbol to find a solution.
Question:
If we take a half of a square, and cut it in half, and then again, and again, an infinite number of times, each time placing the half that we cut next to the previous half, what is our final area in terms of the original square? Assume the original square has an area of 1 square unit.
The engine size, intercooler/piping volume, and mass flow is arbitrary given the constants you have to work with.
No end yet and my feet are getting sore. So I get in my car and follow this infinately long pipe, looking for the end. I follow this pipe through all the contiguous states, stopping to take in the sites to be seen. Mt. Rushmore was cool. Then on up into Canada. Then down to Mexico. This damn never-ending-pipe, never ends.
I then get to a point that it turns straight up into the sky and disappears in the clouds. There must be an end to the never ending pipe up there. So, I get in a helicopter and check it out. Man, I'll tell ya. You can see a lot of stuff from way up here. It's a pretty damn amazing sight to see. However, that damn pipe! Still no end to it. I went as high as that chopper would go and the pipe still disappeared in the distance above me, right into space.
I've gone this far, why stop now? Off to NASA. I'm in space now and following that damn pipe. Wouldn't you know it... it passed by all the planets and shot straight through the sun. That was pretty amazing. Good thing my ship has solar powered A/C.
I keep following the pipe. I increase the speed of my space ship to the Speed of light and everything but the pipe I'm following becomes a blur.
I keep going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going.
And there's still no end to this infinite length of pipe. WTF man? There's gotta be an end to this infinately long pipe. I'm half way there because I know there's one end. That's where I started.
That's about the time I lose interest in imagining an infinite length of pipe.
And there in lies the distinction between Imagine and Hypothesize.
You're crazy. I'm enjoying the hell outta this.
I'm wondering how many more posts about how he doesn't have enough information to do a full thermodynamic assessment of the situation it will take before he forms an opinion and presents a supporting argument given the information available?
Maybe we should start a dedicated "Ask the King" thread.
I have seen it before. The solution I suggest is to turn off the computer (or destroy it) and go outside, find a pool or basketball court and swim or play a game of ball, lift some weights until you are sore and tired, eat a huge meal with anything you want, make sure you get desert, then get a good nights sleep. repeat as necessary until the haunting thoughts of being forced to read the internet forums dissipates completely.
If you wish for the solution to the question I posted the answer is in the shape of the square surface area, simply imagine an infinite number of half sections getting smaller and smaller until you are down to splitting a single atom, what then do you wind up with? I would not ask you to split that atom; instead consider the ultimate consequence of being left with a single atom on the edge of infinity, in the shape provided for you as a single square unit.
Neglecting gravity is important because a vertical straw here on earth of 500' long would be much harder to drink from than a horizontal straw of the same length, so by placing you in a space station or space craft without interference from gravity we are essentially free from determining the orientation of the straw, and can focus solely on the effort required based on the length of it. Also when I say drink, you can imagine drinking air molecules instead of liquid. Liquid has special considerations in space, depend more on surface tension I am told, so feel free to assume the straw is full of air and you are drinking only normal breathable air for this experiment (drinking sounded better than "sucking or blowing air" I did this out of consideration for the terminology, as males tend to differ from being told to suck or blow anything).
First the easy part: If the compressor is tapped, then either boost or power falling off is due to the compressor being out of flow rate. All compressors have some maximum flow rate, beyond which any additional flow is going to reduce the number of moles (molecules) of air even if pressure increases at a fixed volume, due to temperature also increasing. Compressors also have a maximum safe RPM they will typically not wish to exceed; a mechanical limitation like any other engine part that moves must be observed.
How do you know if the compressor is tapped? The easy way is to look at the compressor map. Usually they are in volume/time but can be converted to mass/time, either way is useful. You can calculate the flow rate of the engine at a specific boost pressure, to get a general idea of what the flow rate of the engine would be at that pressure, and compare it to the flow rate of the compressor in question at that compressor RPM. This is usually called charting a compressor map, as you may wish to plot multiple engine RPM points along the compressor map and connect the dots for a preview of what it looks like to run that compressor on the engine. You can search online for hundreds of websites which help you do that sort of thing.
here is the one charted for the compressor on my 5.3L engine I will be running
The red dots are the plotted points my engine is guesstimated to run through as the RPM increases from 1k to 6k, as noted by the red dots. The 1.8 on the left that the red dots seem to trace along is the pressure ratio, it means 1.8 times the atmospheric pressure, or 14.5psi*1.8 = 26.1psi total, or 26.1 - 14.5 = ~11.6psi of boost pressure. Remember that atmospheric pressure counts as some 14.5psi of pressure at sea level, it is like a 100% adiabatic efficient turbocharger ever present in our atmosphere (since the air is always compressed, or already compressed, depending how you look at it) we are only adding pressure on to that in any increment we choose, except that a compressor is not 100% adiabatic efficient and does add some temperature to the boost pressure. The islands on the compressor map show us the adiabatic effiiency; note that my red dots run straight through the center island, and they end up nearly running right off the map at max engine RPM; this is no accident. By taking a full advantage of the compressor map at the desired boost pressure we are using the smallest compressor possible to get the job done, which means the wheel will be the smallest and lightest possible, and "lag" effects will be minimized. By running the compressor through its most efficient islands the air temperature will be kept as low as possible, minimizing the workload of the intercooler and keeping necessary water/methanol injection to a minimum.
Back to the "boost falling off on the big end"
If you have determined that the compressor is not tapped out, and has plenty of flow left in it, there are a couple possible reasons for a boost to fall off "on the big end" or near maximum engine flow rate.
The first most likely culprit is a boost leak. Boost leaks force the compressor to flow more, it moves the compressor RPM up, creating additional exhaust get pressure, which reduces the flow rate of the engine. It also might move the compressor to the right of it's map (falling off the right of the compressor map) which raises intake air temperature rapidly and can cause detonation and engine failure quickly. Therefore, it is essential, absolutely every setup should be boost leak tested, no exceptions. The plumbing needs to be filled with 15psi~ (or whatever you intend to run) of air pressure to ensure there are no leaks. The pressure should stay in the plumbing for quite a while, more than just a second or two, sometimes as long as 15 to 30 seconds is seen, the longer the better.
The next possible culprit is the boost control method is insufficient. There are many reasons for this, such as poor wastegate position, poor solenoid operation, poor commanded attributes, etc... but the point remains this is the second most likely cause for "high end boost falling off". Often the spring in the wastegate is too small for the commanded boost pressure by the controller (if you are using a 5psi wastegate spring and trying to dial it up to 25psi of boost, that is not going to work out very well for you)
From there, you are on to considering the valvetrain and intake method, the flow rate of the head, the duration of the camshaft and associated parts. In other words, if engine volumetric efficiency is falling off, then that is why the torque is falling off, and that is why the power is falling off. This is why torque falls off "on the big end" of engines with stock style camshaft profiles. Increasing camshaft duration may fix the valve timing event profile, allowing VE to be maintained through the rising RPM, but it will not fix problems with the flow-rate of the head or intake design which may also incur VE losses. It is cheaper and easier to raise boost pressure through these regions than to try and fix the head/intake/camshaft profiles associated with VE losses, as long as the fuel quality in question is up the challenge.
Those are the big three, main reasons why power (torque) is dropping off as engine RPM increases to the "big end".
There is something to be said for forum etiquette where you don't clog a thread with random crap and gibberish info from a textbook. Its funny, when you actually start building stuff and getting out in the real world, your reliance on textbook info lessens, but you know the saying.....Those who can, do; those who can't, teach.
Hoping to put something in his mouth to shut him up a bit, a neighboring pit offers him a hot dog. A simple, yes please, or no thank you? No. A 15 minute speach about how hot dogs are made, why they are the shape and length they are, why they plump when you cook them, the chemical composition of the fillers used and other industrial applications that filler is used in.
Then the neighboring pit guy asks, "Is that a yes or no"?
I gave you my answer, but let's talk about...
Nice
So what is it I am not doing? If you think cars/vehicles are important, or that I care about my ET and post stats in my sig like a child, as if it were an important thing to be popular on an internet forum, well that is not the renegade style I abide. I'd rather people in my vicinity think me slow, dim witted and uneducated, it helps them underestimate the situation and the real danger they are in. Nobody knows what is really under my hood or what I "do", I do not boast talk or gab, it is useless.
Be more off topic than usual fiends, the internet has you in it's icy grasp and wont let go!
Nice
