750hp ls1 combo? Critique
5.7ls1
232/238 114lsa cam with springs upgraded
90mm tb
Arp head bolts and rod bolts
75/75mm bullet turbonetics turbo
Powerglide
E85 system for way more than needed flow rates.
Exhaust
With this combo should I expect to see 750 at the crank or pushing it?
Prior to this bottom end on a previous stock one incl standard bolts it turned 540whp which I guess is around 650crank that was on 20inch wheels and 3.07 rear gears.
I agree with regapping the piston rings as well.
With higher boost, you create higher cylinder pressures and temperatures. Materials (including the steel alloys used in piston rings) have a coefficient of thermal expansion, meaning they expand a certain amount with an increase in temperature. If this didn't happen then piston rings would have no end gap, or we would run no piston rings and set the piston to wall clearance at close to 0.
You should increase the end gap to allow more growth with increase temperatures. If you do not, then the ends of the ring will contact each other and continue to expand, causing an increase in mechanical friction on the cylinder liner, ultimately welding the rings to the cylinder liner. Your connecting rods will buckle and your engine is TOAST.
My recommendations for piston ring end gap on your engine would be:
TOP RING = ~0.024 to 0.026 inch
2ND RING = ~0.026 to 0.028 inch
For reference, I run a bit more to be safe but am make more power (more pressure and heat)
Last thing. Are the arp chromoly studs fine or should I get the aged 625+?
And lastly with the e85 and front mount and the bolts upgraded ect what boost should I ask it to be tuned on?
Or should the tuner always aim for no knock and good afrs as opposed to a max boost setting?
Just curious as I see some people saying max psi should be 10 some people say it doesn't matter its a max hp rating some people say no knock and stable afrs.
The issue is not the clamp strength here- its the AL block. You are 400% more likely to pull threads sending bolts back into those holes as opposed to a stud
