Max pump gas HP
Most of you guys have seen my build on the S10. Dual 044 pumps, 80lb Deka injectors and Meth injection if needed. A2W IC. S482 on a SBE 370". I would like to see 900-950 rwhp but may not get close enough on pump gas. We have 93 octane here for super.
I am going to get C-114 if I get the race gas, but its about 16.50 per gallon. And I had to drop 2k on my trany this week which wasn't planned. Just trying to see what is possible and figure if I can be competitive in a race coming next month.
It has Mahle Pistons but gen4 rods and stock crank in a 6.0 LQ4. I'm worried about the rods mainly.
I am sure its been talked about in one of my threads but I cant seem to find it. I just wanted to ask since I am short on time. I need to get a drum fuel by Friday if I need it.
For most part it's going to boil down to whatever compression ratio you choose.
if you pull timing in the lower rpm full boost range and don't let it go lean you will get decent numbers but if you push it and it rattles hard it will pop a gasket or break a ring land.
deka 80s will go a long ways on gas .I don't think a 1000 is out of reach at all.i don't know the hp numbers but my friends Camaro that I tune has ran 9.44 at 3600 lbs with 80s on e85 @ 97% d.c. 58 psi base and 1 to 1 rising regulator.
I then made one last pull after setting things up and tested the AFR safety and it worked. Shut the engine down and came back as it should.
My base compression is about 9to1.
My question really wasnt to ask how much can my engine make. Its really just asking if the gas itself is capable on an engine like mine. I know there a lot of factors. But if the opinion is 700whp then I am getting the race fuel. If its 900 I might see what I can end up with.
The turbo to a large degree will be a limiting factor as much as anything else.
But pump gas+meth the engine itself will have no difficulty making 4 figures as long as it has the supporting parts to do so. Your compression is sensible, so I wouldnt even see an issue hitting 900 on pump alone with good tuning as long as your turbo will support it at say 20-25psi, no more.
I am most likely going to get the race gas and be done with it.
