Blow through setup. Obviously I need some help.
For your idle being so rich you probably need quite a bit bigger IABs.
What fuel pump is it exactly? 45lbs or 45gallons? 45 lbs per hour wouldn't feed a stock Civic!
It sounds like your floats might be set too low. Do you have jet extensions in the back?
You prob don't need 110 in the car at 8 lbs., but 100 prob wouldn't be to far off, unless your planning more boost.
I have had Kevin (CSU) do several carbs, always spot on-does your carb have rem. air bleeds? Some of those wide bands wont read correct if to rich,
can give false readings.
You prob need to drop the hi speed A/B's down to .022-.023 to richen the top end, reduce the jet sizes, and a boost ref PV to ensure its open.
