Turbo hot pipe smoothing
Old Apr 17, 2017 | 05:34 PM
Gotit4cheap16's Avatar
Default Turbo hot pipe smoothing
I got my turbo hot side pipings neck extended and welded a T6 flange on it. My question is do I have to completely smooth out welds on the inside of the pipes where it's welded for the air flow? Will the bumps interfere with the turbo air flow going in? I am installing an s480 turbo. Pictures below.
Attached Thumbnails Turbo hot pipe smoothing-20170417_174252.jpg   Turbo hot pipe smoothing-20170417_174325.jpg   Turbo hot pipe smoothing-20170417_174332.jpg
Old Apr 17, 2017 | 05:52 PM
ddnspider's Avatar
I wouldn't do it for airflow, I'd do it for preventing those tiny bits of slag from breaking off and going through my turbo.
Old Apr 17, 2017 | 05:54 PM
I've actually gotten rid of all the tiny pieces that could break off into the turbo. So you are saying other than that my air flow will be good and don't need smoothing for the Weld bumps?
Old Apr 17, 2017 | 06:24 PM
ddnspider's Avatar
How much power/boost you trying to run? Either way, I doubt that would be the difference if you ran into any kind of backpressure problem.
Old Apr 17, 2017 | 06:48 PM
brandon6.0's Avatar
I don't see that being a problem. Id run it just like it is. Ive seen some sloppy welded turbo kits that looked like they would fall apart and make damn good power. Sloppy Mechanics comes to mind lol.
Old Apr 17, 2017 | 07:05 PM
sbcgenII's Avatar
Bad welds make power until slag breaks off and gets jammed in the turbine.
Old Apr 17, 2017 | 08:15 PM
With the s480 Billet I'm adding, 800-900
Old Apr 18, 2017 | 06:24 AM
roastin240's Avatar
Why not smooth it out? Takes very little time. Takes about as much time as starting this thread and following up with it. I always die grind the inlets and outlets of exhaust plumbing, manifolds, turbo inlets and outlets, etc. Figured its worth the extra time considering the hundreds of hours already invested into the project.
Old Apr 18, 2017 | 06:45 AM
Thats very true
Old Apr 18, 2017 | 07:27 AM
Nali6.2's Avatar
tig and back purge prevents this. eating up a turbo will be an eye opener.
Old Apr 19, 2017 | 08:52 PM
rpturbo's Avatar
I agree, but not everyone has a tig, and especially setting up a backpurge. Granted, there is a sloppy way of doing it, but really my point is, not everyone has a tig, and just burn it up with a mig or stick.
Old Apr 21, 2017 | 10:58 AM
93camaro_zzz's Avatar
I always smooth it out, as long as I am able too. I figure, I only have to build it once. (Hopefully). It's just something that would bug me, if I didn't do it. I would know it's in there. lol This is just me.
Old Apr 24, 2017 | 07:02 AM
Nali6.2's Avatar
there is plenty of shops out there that charge a minimal price to burn pipes together. that's what ive done tacked it all together then brought it somewhere to have it all welded together the right way
Old Apr 24, 2017 | 08:10 AM
truckdoug's Avatar
I had always heard of these shops, but never found one. Now that I do turbo pipes as a side business, I'd never weld up something I didn't fit up.
not to say there isn't a place for stitching a hotside together with Flux core. Just turn the voltage and wire speed way down to you don't burn through. Maybe try a weld backer like solar Flux?
Old Apr 24, 2017 | 08:22 PM
fisherboys's Avatar
an end grinder with a bur bit and then a sanding roll will clean it up pretty nice
Old Apr 24, 2017 | 09:30 PM
kbracing96's Avatar
I'm one of those shops. I like helping local guys out. Most of my biz goes out the UPS truck so meeting the locals is fun for me. If you're ever down here in the Sutherlin/Roseburg area, let me know. Would be happy to have you stop in a shoot the breeze.
Old Apr 25, 2017 | 07:34 AM
Nitroused383's Avatar
So is it just me or is the inner bolt holes going to be a huge leak?
Old Apr 25, 2017 | 08:05 AM
truckdoug's Avatar
I will do that! we usually get a fishing & camping trip on the umpqua every year or two.
Old Apr 27, 2017 | 05:37 AM
I ended up screwing bolts into the inner holes
