Twin turbo foxbody
Looking at money spent VS options I’d be looking at the HP or MS3. Dominator is ridiculously priced IMO. If you plan on running high impedance injectors anyway (like the suggested Deka 80’s) the MS3 or MS3X has more functions. On the other hand, the Holley HP can run low impedance injectors which opens up cheaper injector options when you want to go over the 80lb range. If you don’t need that… the MS3 makes more sense to me.
Surge tank idea would be the best bet IMO. You don’t need a sump and you can use your factory tank while retaining your fuel level senders and factory intank pump. Here’s my setup. Bought a new tank with OEM fuel pump and senders all installed cheap on EBay. That feeds your sump tank. From the sump tank I run the AEM380 to the fuel rails.
Plumbed like this
