JE piston ring gap for turbo
Old May 4, 2017 | 08:44 AM
z71vortec's Avatar
Default JE piston ring gap for turbo
in the instructions it says to gap my top ring at .020 and bottom ring at .022... but i see guys on here gapping them much larger... any reason why? should i re-gap mine larger? i dont have pistons in yet but now would obviously be a good time to do this.
Old May 4, 2017 | 09:04 AM
dw456post's Avatar
I don't know if there is any difference in turbo or roots but I gapped mine at .023 top, and .025 second, .015 oil rails. So far so good, only 11# boost. Kim Barr racing prepped my block and the rings sealed good.
Old May 4, 2017 | 12:50 PM
jrtoffroad's Avatar
How much boost you running and what size bore?
Old May 4, 2017 | 07:41 PM
z71vortec's Avatar
Its a 8.9:1 comp. Motor built for boost so I'm guessing max would be around 20-23 and it's a 4.005 bore piston.
Old May 5, 2017 | 08:42 AM
truckdoug's Avatar
je says bore X .005 for top and bore X .0055 for 2nd which is kinda tight to me
weisco says bore X .0065 for top and bore X .007 for 2nd which more better i think
i use cheap cast iron rings and cast pistons and run 'em at .026 top and .028 2nd
Old May 5, 2017 | 09:19 AM
jrtoffroad's Avatar
Interesting since Wiseco and JE are the same company. 0.026 & 0.028 is probably pretty good recommendation, I might go 1 or 2 thousands tighter for a 4.005 bore.
Old May 6, 2017 | 01:18 PM
Chris'stransam's Avatar
I did 22 top and 24 bottom . 4.006 bore and stock stroke on a LQ4 block with LSA heads with a Novi 2200 with the oil slinger removed so I can spin the fuc% snot out of it . Shood be good to20-24psi
Old May 6, 2017 | 03:19 PM
stevieturbo's Avatar
Instructions almost never state specific gaps.
They give you options based on usage.
Choose whatever option best suits your usage...and never too tight.
When did that happen ?
Old May 8, 2017 | 05:39 AM
z71vortec's Avatar
ok guys i ended up going with my gut and your responses and took my tops to .025 and lowers to .027... thanks alot for your input!
Old May 9, 2017 | 11:00 PM
truckdoug's Avatar
they're owned by the same company, PMI since the late 90's
last i cared to look they were still separate manufacturing entities
