LSA charger on an LS2 - educate me
I'm aware of needing the adapter plates to suit the cathedral port head, my question relates the driving the charger. I'm worried about belt alignment. Will an LSA balancer go stright on the LS2 crank and line up with the charger? I believe it is an "f body style" belt arrangement on the car.
Also, will the tensioner arrangement bolt straight up? I couldn't find a detailed enough photo to show how it mounts up.
Cheers, Ben
Or possibly...very possibly the last of the Monaro's might have run the closer belt position.
Either way, it's all very doable if you can piece together the parts. If someone sells a proper kit though, it always makes things easier.
The blower adaptor plates are cheap and a lot easier than heads. But I guess swapping heads too could be an opportunity for upgrade, assuming they're happy with your bore size.
the ADM kit does look good, however, the price of the kit plus shipping and import duties to Australia is getting REALLY close to the cost of a Magnuson kit sourced locally.
In Australia, we have the VT, VX, VY and VZ, each version was essentially a facelift of the last and all came with the LS1 (and the normal camaro style belt drive) bar the last of the VZ's, which got LS2's.
After this came the VE and VFs, which had L98, L76, L77 and LS3s. I believe these all had the shorter snout and drive. There was only the one model in the middle with the LS2 and I'm not sure what stylee belt drive it is. I can physically measure this, but that doesn't tell me where the LSA balancer/crank pulley will end up.
Is the LSA a shorter snout/corvette style setup?
Your current water pump should be fine, but you'd need to move/change alternator or PAS pumps and associated parts.
Is it a big bell water pump or one with the smaller more square faced pulley ?
Crank pulley obviously and probably move the aircon pump back if fitted.
In some cases it's probably just mounting bracket changes really.
moving the Alt, PS and AC is exactly what I was trying to avoid. By the time we buy all the bits, or the whole kit from ADM, it's getting close enough to the price of a Magnuson that I'd rather just buy one of those.
jimmyg, I did see banditdaves thread, he just changed all his accessories to suit.
My only concern is belt slip. The pulley is tiny at 2.45", presumably because the crank drive is smaller than the LSA supercharger drive pulley. Couple that to a 6PK belt instead of the normal 8PK, and it will surely get interesting. Being that my mates car already has the head+cam combo, we may want to turn the charger a little harder, but will have to look at an overdrive balancer for that at a later date.
