Will these parts work together
05, lq4 took apart and everything looked good inside. Will keep this
BW s400s turbo. Part # 171702.
Comp cams 54-000-11 dur@.050 int 227 exh 231 lobe sep 114.0 int. 623 lift exh 598 lift.
Tooley spring kit. .660 lift 155lbs @ 1.780 400lbs @ 1.070 with retainers shims locators locks and seals.
Comp cams 7.400 pushrods
Well what do you think? Did I get lucky?
https://www.liljohnsmotorsports.com/...ge-ii-cam.html
Also some free advise for you is make sure you have the ring gap correct for your power level
We all can learn from others mistakes.
Good Luck , hope to hear more about your build as it progresses.
Also Check out the Sloppy Mechanics WIKI site By Matt Happel AKA (Denmah)
Not a single person asked him what his goals were, primary usage, fuel, etc.
They jumped straight on the VS 80mm/LJMS Stage 2 bandwagon, because cookie cutter builds are a thing now.
I have a 4l80e also and maybe down the road a t56
