My 97 S10 at the track
These videos were from last night during our test hits in Grudge races. We are racing today. Its the Dirty South No Prep series and I will be running in True Street. Some cars run mid 5's and a good car will run low to mid 6. We aren't getting time slips so no one knows what its actually running. I can tell you I ran a 6.48 leaving on 3.5psi and 14.5 down track. It made 700rwhp on the Dyno at 16psi.
So here are a couple videos of last night. We are hoping the track will continue to hold me at launch so we can keep hitting it hard and try to win this 5k. 1st hit was on baseline shock settings. Front jumped too fast so I firmed the front up a little. 2nd and 3rd hit was after the initial change. Caltracs are still at base settings as are the rear shocks. By looking at the video it moves to the left a little at the hit so this will get a Caltrac adjustment today to try and solve that.
As for the race yesterday. The track was super hot, up to 147 degrees. It was cooler when we were up but cars were having tractiin issues. So we pulled a little after launch timing for a second or so and I went in too quick which didnt let it get to full spool. Left of 8 instead of 13.5psi. So the 60ft was slow and I got beat. I also underestimated the Mustang I was running against.
So now its time to drop 300lbs and make some suspension upgrades. If thats not enough for mid to low 5 second pass then its mo-powa time. This true street class was a bit of a joke with the cars they let run it. They made the 20 mile cruise but they werent street legal and were lacking in keeping to the rules.
As for times, I can give a little info. This being a no prep event we aren't allowed to get times or slips. On the last test weekend, which was the last Saturday, it went 6.48 with a 1.64 60ft time, left on 3psi and made 14 about 2 seconds after launch and held that for the full pass.
This weekend I left on 13.6 psi and was making 20psi 1/2 second after launch which held the entire pass. I am going to guess very high 5 to very low 6 second passes. Its the first time it ever felt fast to me.
At the dyno it made 700rwhp at 14psi. But we couldn't get the load we needed on it to build more.
I'm going to knock some weight out of the front end and work on harder launches and more psi after launch. I am thinking about 23psi max for this stock rod motor. So far I'm not running any safeties like Knock or AFR. We have been pretty careful in getting the power to this level. So far running it on C14 and no meth injection.
I think you are going about it correctly though trying to iron out the launch and get it lighter first though. Once you have it dialed in you can use the boost by RPM/boost by speed functions and bump it up to 25-26lbs easy IMO. My radials usually like to be hit really hard with a stiff front end.
Good luck!
. Nice work !
