Custom AC line help, ideas??
The flange is angled for a reason, if pointed straight up then the flange will stick out further than required.
Shoot me an email please, happy to help however I cannot help if I am not informed of any issue.
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
The placement of the turbo allows us to run a variety of turbos as mentioned above, and the angle of the flange allows for that.
Pair of 16925's work excellent and have zero issues fitting with the kit or cooling the set-up.
You are welcome to use something different if you desire as mentioned, and I can assist you with a custom AC line if you desire from one of the companies we work with to make AC lines for our Corvette kits. Shoot me an email and I would be happy to help!
I just don't want people getting the wrong impression on requiring unexpected modifications with the kit.
Thank you! Shoot me an email and I'd be happy to help out with whatever you need.
I got a Be Cool rad and had to move stuff forward and down to make it clear. With moving stuff forward I had to extend the top line for the A/C. I'll snap a pic of it sometime this weekend if it ever clears up and quits raining. If you take your current line to any Hyd hose shop they should be able to put a 6" extension in there cheaply for you. Haven't charged my A/C system yet but driving around with the current setup in stop and go traffic I hit 175 where my first turn on temp is at and in traffic on a 80* day it has no problem bringing temp back down to 170.
Most cities have a hydraulic shop, can't run much equipment without them, the only bit they may have to order is the hose with the liner that tolerates the R134,, but thats not a long term issue, I've also just had them make me an extension male to female to extend a hard line..
