Is it possible to have a new turbo that is bad? What can be wrong with them?
Been chasing low power issues since my combo has been together and someone suggested maybe one of my turbos is defective. I do occasionally get a little burning oil at idle and spooling seems slower than it should be. What can be wrong?
Cat has been running street/track for months now, runs very well, on track pulls afr is between 11.2/11.6. peak timing of 22 degrees on E 85, duty cycle barely his 50%. Its a 427 lsx 9.7/1 motor. Twin Borg 76/82mm. Everything feels normal, doesent lay down in the middle of a run or anything, just doesent make the power it should and it seems to spool much slower then it should
Turbos are very simple items really.
If the shaft is free to spin, not excessive free play etc and no obvious visible damage, then chances are it is fine.
You're saying it's burning oil at idle....and you have twins. So can you pinpoint it to a single unit ? Are there visible traces of oil on the turbine wheel or housing ?
Oil drains all good ?
I did a smoke test on the exhaust and a pressure test on the cold side, both came out good, I haven't pulled the turbos apart to look for burnt oil, oil drains are-10 with 45 degree fittings on both ends and steady downward run. I did a few pulls on the street today up to 25 psi, blew the tires off it but I wanted the data, when I was in the 10-15 psi range my BP was 20-30 psi and held fairly steady as boost caught up. It's not great but I don't think that's worth several hundred hp
So you applied boost pressure to the compressor cover, through the inlet, all the way through to the engine/throttle body/intake manifold? How much pressure did you use? I am sure you found some small leaks doing this.
