holley hiram surge.?
lq4 ,218 jarrett cam,holley hiram ,war 100mm t.b., microsquirt.
I have changed ecu's plugs,coils, ve table and no change. this engine has been ran and driven with this tune and ecu but not with the big intake and t.b. it is like it is getting a fluttering in the intake and I cant fix it. any ideas will be apprecieated.
I have a log I will try to post.
Problem area is 1700-2200 3-4% tps. Only way mine quit was adding fuel, setting learn to
0(Holley) & lowering closed loop comp limit to 3. If I go leaner than about 13.5-13.7 surge comes back.
Have thought maybe the 90mm throttle body might be contributing but am too lazy to try a smaller one.
I might try a stock truck intake and see if that does it. if so it might stay that way.
Do you have any silly closed loop features active ?
Injector pulse widths do not appear to be changing massively....so is your wideband reliable ?
Presumably you're saying this is a real and noticeable problem when driving, and not just that you're seeing things on a log you are not happy with ?
What is ignition timing doing during this ?
Upload a full log.
tried my ecu and tune from my nova that is great and it does the same thing no change at all. the only thing different is holley hi ram and huge t.b. and tps sencer. everything else has ran good on this tune /engine. thanks .
EDIT. The pw goes down initially when it starts fluttering. does the tps sweep smoothly KOEO?
This is why I said scale the TPS. Open throttle 60% and set it to the max. The larger TB flows as much at 55-60% as the smaller does at 100%, so it will cause your accel enrich to act as if you are using the smaller TB again because airflow/TPS% ratio will be restored.
