Supercharging my 07 Z06
Old Jun 21, 2017 | 09:05 AM
whazard's Avatar
Default Supercharging my 07 Z06
I have a stock z06 and I am considering having a blower installed but would like some help figuring out the best route for me.
So far I am torn between the A&A kit and a Procharger. Also would like to do aftermarket heads since my heads are still factory and dropping a valve is stuck in the back of my mind and a cam to help squeeze out a little more power without having to run to much boost on the stock bottom.
My goal is mid to high 6XXwhp on 93 with potentially going e85 down the road.
Any help is much appreciated!
Also, if anyone knows of a shop in south GA that would give me a good out the door price on all the parts and install that would be great!
VtoZ is offline Report Post
Old Jun 21, 2017 | 09:28 AM
JoeNova's Avatar
Restricted User
1. A&A vs Procharger is up to you. I don't have any experience with A&A. Procharger has probably made a hundred times more units than they have. Bob @ Brute Speed might give you a killer deal on a Procharger assuming he has them for a C6Z
2. The issue with dropping valves in LS7 heads is due to the exhaust valves. Replacing them is way cheaper than replacing the heads. You certainly don't need the extra head flow.
3. Your bottom end doesn't care how much boost you run. 800 ft-lbs is 800 ft-lbs. It doesn't matter if its on no boost, 5 PSI, or 50 PSI. There isn't any additional stress at a given power/torque because of a different amount of boost.
Old Jun 21, 2017 | 09:37 AM
AnotherWs6's Avatar
There are several local guys running Edelbrock SC's in my area. Dunno much about them but they seem to be popular with C6 guys. Who are all older if that matters???
Old Jun 21, 2017 | 10:06 AM
hellbents10's Avatar
LS1Tech Sponsor
The stock Ls7 bottom end is a little delicate with boost. High compression and thin sleeves are not good for durability with boost.
600rwhp can be had with good porting of the factory heads and all supporting bolt ons in NA form.
Old Jun 21, 2017 | 11:55 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thumbs up
Thanks, I appreciate it! I do indeed sell them for the C6Z. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jun 21, 2017 | 01:02 PM
ramairetransam's Avatar
You have a c6z , i would skip supercharging and go with a 2inch header, ported fast 102 and a heads cam package to get you to 600 whp .
Old Jun 21, 2017 | 06:40 PM
SELLSZ06's Avatar
X2
call Bob
and im super happy w my F1... and
get least a d1x bc you will want more.
Old Jun 21, 2017 | 06:46 PM
LS1Tech Sponsor
Thumbs up
Originally Posted by SELLSZ06
X2
call Bob
Thanks, I appreciate it!! Bob
__________________
