oil pressure issue....NEW UPDATE!
Oil is Joe gibbs ls30. Oil temp was a high of 240 but quickly cooled down.
I went and did a cold start this morning and its normally 70ish and it was 40 this morning. again no motor noise.
Any ides guys? Thanks.
UPDATE: So upon tearing the car down, I removed the trans from the motor and the shout to the PTC was a screw on...and it backed it self off the converter and was laying in the snout of the crank...WEll it was DEF the thrust bearing. the converter was practically punching the crank under throttle I'm assuming.
Dropped the motor off at the machine shop, said it heated up a main cap a little bit and hot spotted the crank but its still straight and true. MY question is now. the mains before were .020. with 5w/30. should be open them up to .025-028 with either 15w-50 or 20-50? Last question, I have no trans pump restrictor...should I get one installed while the trans is out now? Is it necessary?
The last pic was after 5 hours. lol
Nobody can tell you what weight oil to run unless they built your motor and know the clearances. Putting in thicker oil might make your oil pressure gauge look better but that's not fixing problem.
Pull the oil filter and cut it open. DO NOT run the engine! If it is hurt you'll be sorry, a small issue can turn into a big issue very fast. What could be just bearings, can turn into new rods, crank etc....
At least that's what happened to me.
I tried AmsOil, VR-1 and Royal Purple and they all seemed to thin out quickly and required more frequent changes.
I bought some Delo 15-40 on sale at Costco and has been the best by far, pressure is the most stable, recovers from heat quickly and keeps it color the longest not to mention its cheaper than the aforementioned by far lol.
$.02
$.02
I put a remote unit with its own fan on this past winter, it really helps.
I turn it on after I'm done beating the cars *** and it brings the pressure back up a little so it must be doing something.
Stuck some Valvoline conventional 20-50 VR1 in it and pressure is back to normal. Although part of me still thinks its hurt lol.
