Silverback build thread - 347 S485 TH400
Old 01-11-2018, 09:29 AM
  #81
98sscammed's Avatar
Originally Posted by Mavn
I saw this Car at SCT in Dallas. I was in the stick shift class. The 2002 SOM SS
I have always loved those SOM Camaros. I will be out there again in April in their new 9.50 class so say hi if you see me. Even well into the 8s, I will still be too slow for true street so I will just turn it down and win the race in the 330’.
Old 01-18-2018, 08:33 PM
  #82
98sscammed's Avatar
I have the transmission out and going to upgrade to a REID case and bellhousings since it is really hard to get a shield in our cars. I am also sending my converter back to FTI to be restalled. I have been also knocking out little odds and ends but should be starting the wiring soon.
Old 01-18-2018, 08:35 PM
  #83
98sscammed's Avatar
There is a protective film on the carbon fiber inserts that I made....and yes it is real carbon fiber.
USB is for the Holley ECU and Dash
Old 04-06-2018, 09:12 AM
  #84
98sscammed's Avatar
It’s been a while since I updated this and have made lots of progress. I am going to get the car tuned on Monday and will be participating in the Dallas Streetcar Takeover on the 21st. I am too slow for true street since you need to run 7s here in TX to be competitive so I will be entering Real Street 9.5 class and turn the boost down. Come say hi if you see me out there.
Old 04-06-2018, 09:17 AM
  #85
98sscammed's Avatar
That harness line on the passenger side is now tucked.
New PTC converter since I was blowing through my old converter.
Upgraded my trans since the old one turned out to be trashed. I also needed the SFI case since I am signed up for Drag Week 2018 and can’t fit a shield in my tunnel and didn’t want to mess with the CSR shield.
Old 04-07-2018, 05:43 PM
  #86
C5_Pete's Avatar
What dash display is that?
Old 04-07-2018, 05:49 PM
  #87
98sscammed's Avatar
Holley 7” Dash.
Old 04-07-2018, 06:07 PM
  #88
C5_Pete's Avatar
Thanks, looks great and good luck with drag week!
Old 04-10-2018, 05:26 PM
  #89
98sscammed's Avatar
The dyno went well but started seeing the effects of my full 4” exhaust. It also wasn’t able to load up the converter quite right or I am starting to blow through it on the highest boost that we tested. Final numbers were 1029rwhp and 1109ft lbs. I will be adding meth and maybe the BTR intake manifold when it comes out.
Old 04-12-2018, 04:26 AM
  #90
slowlsx's Avatar
New converter and it’s already blowing threw? What is the stator in it?
Old 04-12-2018, 07:05 AM
  #91
98sscammed's Avatar
Not sure but want to get the car on the track and data log with the weight of the car behind it to properly load the converter before I start pulling it out. PTC spec’ed it for 1100-1200 at the tires and started seeing slip past 1000. I will be racing next weekend but entering at 9.50 class. I will try and slip in a full pass at some point though.
Old 02-22-2019, 08:04 AM
  #92
98sscammed's Avatar
Wow a lot has happened since my last post so I will just hit the basics.
-Drag Week is AWESOME and survived the week.
-Got a new carbon fiber hood
-Added meth
-New personal best is 8.78@154 with plenty to improve on
-Winter upgrades are TBM Brakes, Champion wheels, Moroso oilpan, BTR intake manifold, Holley 105mm throttle body, new puller fan setup, other small misc.
-I will be entering Drag Week again in 2019
-Goals for 2019 are to get the car into the mid 8.4s to be able to run a consistent 8.50 at Drag Week in SRSBPA, go to a couple local races, and most importantly enjoy the car more this since I hope to not be thrashing to get the car ready for Drag Week.
Old 02-22-2019, 08:10 AM
  #93
98sscammed's Avatar
Old 02-22-2019, 08:28 PM
  #94
01RedZ28's Avatar
Love this car and the build thread.. Its gotten me motivated to get back working on my car.
Any more pics of the new wheels? Are they single or double beadlock?
Old 02-22-2019, 09:09 PM
  #95
98sscammed's Avatar
Thanks! Single beadlock.
Old 04-08-2019, 08:52 PM
  #96
98sscammed's Avatar
I am getting close to having everything wrapped up for a re-tune and to race May 5th and then the Oklahoma Streetcar Takeover on May 11th. Just need time in the garage.
Old 04-08-2019, 10:30 PM
  #97
"I MAID THEESE"
Mavn's Avatar
take any videos during drag week of you cruising the car ? that's my favorite part lol
Old 04-09-2019, 06:47 AM
  #98
98sscammed's Avatar
I took one in the switchbacks up in the mountains. We were going up hill so my turbo was whistling the whole time but the video didn’t really capture it.
Old 04-09-2019, 11:05 PM
  #99
LilJayV10's Avatar
That car is impressive for sure. Did you end up using the factory BCM and the Holley to keep everything working in the car?
Old 04-10-2019, 07:17 AM
  #100
98sscammed's Avatar
Thanks and yes. One day I will strip everything thing out and make a harness to replace it but that is a few years away.
Quick Reply: Silverback build thread - 347 S485 TH400
