Project Hairy Banana (1967 Camaro single turbo)
#221
LS1Tech Co-Founder
I ordered the computer along with the their coils and a screen. Ouch.
I'm running my motor set back an inch, T400 and 9". I need to get a DS for the current rearend, though I'm already planning (scope creep) to buy better rearend parts later this year.
#225
LS1Tech Co-Founder
- Most of the of Holley EFI showed up
- I'm on the hunt for all of the engine sensors
- My buddy is going to come over and we are gonna dig into the wiring tomorrow Monday.
#227
LS1Tech Co-Founder
My understanding is I am supposed to use OEM sensors for
- crank
- cam
- head coolant temp
- IAC
- TPS
#232
That's a matter of prospective, I feel like I'm close compared to where I was...lol
by https://www.flickr.com/photos/106395947@N06/, on Flickr
Hoping to make LSFest in September, if I do, I'll be naturally aspirated.... I've plumbed my brakes, half of my fuel system is ran, I'm rewiring the car from scratch, I've got the Holley stuff sitting on the counter, and I'm throwing together a junk 4.8 with a 4L80E. Going to leave it in primer and no interior just to get her going. I'll probably do the turbo kit this winter once I get the bugs worked out.
https://instagram.com/zboss86
#234
LS1Tech Co-Founder
zboss if I can bring mine to LS Fest, it will be a 10 footer for sure.
Okay so I might as well do an update:
My goal is to get the wiring at least 70% done in next 7 days.
- Sensors getting most of them from brotha Cam. Thanks sir.
- Just ordered headlight and taillight harnesses (nice used) from Ralph @ Chicago Motor Car Parts. My front harness ls cut off, and the rear looks sketchy and broken.
- I am going to order another radiator (great idea Mario!), I will take some measurements and get one like the one you suggested.
- Classic Dash makes a Holley Dash custom version, will order this:
- I am going to paint the other valve covers when they show up, then mount the smart coils on the ICT brackets.
- Once I have sensors I will will install as much of the Holley harness as possible.
#236
LS1Tech Co-Founder
Car's wiring is pretty lame. I decided to pull the Autometer gauge setup out, since I'm going with the Holley dash. I pulled a bunch out, but left some in because it might help me or whomever wires the car understand how stuff was routed.
#237
LS1Tech Co-Founder
If I can install one thing a day I'll be finished at some point right?
Last night I re-installed the ICT coil brackets correctly, the spacers go under the coils. I could not install the coils because they did not come with my order (back ordered I'm guessing).
I also finally installed the ICT truck alternator (LS3 water pump), what a nice little setup. Alternator is 4 pin high output GM version. I did not install the overdrive pulley on the alternator because I'm not sure how to take the stock one off lol.
