Project Hairy Banana (1967 Camaro single turbo)
#1181
LS1Tech Co-Founder
When it comes to alignments, the old suggestion was have the fronts tipped in a bit to to the middle, anyone Jamie? have any thoughts? How about castor, friend said 7% back or something.
#1182
Depends a bit on the intended use , but for a street car you don't want much negative camber ( in on top ) anything more than 1° will cause bad tire wear and looks terrible IMO. I shoot for 0-.5 °. With stock front end parts it's hard to get a lot of positive caster but you can usually get a couple degrees ( likely more with aftermarket control arms ) usually try to get them close to the same and as much as can be had with stock arms. Adjust them separately if there is any amount of pulling one way or the other. For toe in , 1/8 " measured at the tread has always worked for me. Just my opinion on this but I've done quite a few muscle cars this way.
The following 2 users liked this post by GMCGreg:
3 window (12-01-2021), JinglingBaby (12-01-2021)
#1184
LS1Tech Co-Founder
This week has been a real bust for getting an alignment in, my wife and I are too booked up to get it in this week. Still trying for next week.
Engine #2 Discussion...
Okay so I'm trying to finalize the final parts list, but it sounds something like this:
- My bare LC9 block
- Summit Racing Pro Series crank, rods, and pistons to support 1400 someday
- MLS head gaskets, I have no intention to get into o rings and stuff like that
- Baker / Capizzi hydraulic roller
- Brodix heads
#1185
LS1Tech Co-Founder
I'm back from a week of vac in AZ/UT, let's bump this up because we all know this is one of our favorite builds even though it took me 3 years to build it and I have not made any passes yet.
Updates, it finally snowed here and they salted the roads booooo.
I have a LJ steering wheel to swap on, and I need to order some double adjustable shocks for the rear. For the shocks either I go budget and get Strange or Viking, or spend more and get Menscers or regular Afcos.
#1186
- My bare LC9 block
- Brodix heads
The following 3 users liked this post by 3 window:
The following users liked this post:
3 window (01-03-2022)
#1188
I've got double adjustable Vikings on my 4th gen currently and made a couple soft standing start hits on the street and it hooks hard.
Front end comes WAY up and car moves out, I know its not apples to apples but I've been very impressed with them so far.
Time will tell when I hit it on the brake at the track....
#1189
I’ve got double adjustable Vikings all around for my new ‘66 Malibu project. Going injected this time, blow thru was ok but MSD 6014 was frustrating. Had rear DA Vikings on my ‘81 Bu and they hooked good w a 275 but going to 295s this time since new car is back halved.
The BallSS (01-04-2022)
#1190
#1191
LS1Tech Co-Founder
JIngles I'm rolling on 295/65s right now car hooks almost too well lol. I'll have to leave on some power for sure. Maybe you and Jamie can come up and video me putting it on the bumper at the Grove.
I've got Viking double fronts brand new on the car, and the rears are single Strange which I'd like to swap out and I got them for $100 but they were new.
#1192
#1193
LS1Tech Co-Founder
My buddy Kevin who runs a single S483/370 combo in NJ is swapping to pricier shocks, his QA1 fronts release too fast if you know what I mean. So might get Menscers which will have a slower rate of drop.
#1194
You can revalve the Crusaders yourself. It’s basically a needle and seat you swap out. Parts are about $15. Probably $350 now FJB
The BallSS (01-05-2022)
#1195
#1196
JinglingBaby (01-04-2022)
#1198
I'm at the same spot, rear suspension time! The shocks are the only spot where i'm not sure which way i'm going. I called Afco after reading online about possible longevity on the street and they said they suggest getting them rebuilt every couple years for about $125. This is for the Big Gun X's. I don't know if that will hold true, but maybe. Otherwise, it will be Viking Crusaders for me.
#1199
Is there a mileage window?
I would imagine the road condition plays a huge role for example the roads in California are horrific when compared to the roads in Washington State so I could see shocks wearing out very quickly on CA streets.
Additionally, I can't speak for you obviously but I put maybe 1,000 miles a year on my car so the Afco's may last quite a while if you're similar?
#1200
LS1Tech Co-Founder
If i was running a series like some buddies have I'd pull the shocks end of every season and have them checked over, some friends have blown that off and then had shock issues because they think they can go 4 years without servicing them. I'm not speaking as an expert, I'm not sure how high maintenance they are but I've seen a buddy or two lose a race because they had a blown-out shock.
For my rears I'm thinking Afco, Strange or Viking. I'm kinda thinking rear shocks are not that big of a deaas the fronts, would anyone disagree I'm really open minded on this.
