What's there to gain?? Turbo swap
Switched from a Turbonetics 7668
And Just pulled the trigger on a
VS Billet 7875 as I think it'll meet all my goals and then Some
Combo is 5.3 SBE Gen 4
Stock heads
BTR Stage 3 cam kit
E85 Blow through carb
Victor Jr
All in a 3000 pound RW mustang with a glide
We're switching turbo and fuel the car has been 9.70 at 140 with the smaller turbo and 93
Stock heads
BTR Stage 3 cam kit
Victor Jr
Stock heads
BTR Stage 3 cam kit
Victor Jr
Stock heads
BTR Stage 3 cam kit
Victor Jr
What fuel are you using? That could be a big game changer. The difference between 93 and E85 is pretty big and the jump to 116 is even bigger. That turbo should pull much harder on the big end sooo there's that? Kind of hard to say. There are so many variables when you change fuel. Could be much more timing or boost and that changes a lot. Best thing you can do is plug it in an online calculator well that's second best the best is to install and take it to the track and be surprised when you hit low 9's
we ran 9.44 at 140 with the 78/75 at 3550 lbs race weight but it seemed like we were chocking from the small turbine . 5.3 engine and 20 lbs boost.
the switch to e85 should give you a tenth alone with no other changes,
the .96 ar of the 78/75 will be the issue when it max,s out .
hp number aside my guess is you can go 9.0 to 9 teens and 150 or so before it starts just making heat,
that turbo is louder than your turbonetics.
That will change up my whole hot side and not wanting to do that right now this will have the same outside construction where it'll be a plug and play. The S480 was deff an option and once the motor pops will likely be what we step up too
Now that we're waiting for it to pop it'll likely last forever LOL
Out of curiosity if you guys are maxing 7668's it seems like a 7875 while a good increase isn't THAT big of an upgrade. Wouldn't you be better going with a on3 84/75 or a vs88. Shouldn't have to change your piping and leaves a lot more room for growth
