Best recipe for 800rwhp ? Turbo 5,3
So , first turbo build. Looking to make 800 wheel thru a 4l80. Gen 3 5.3 going in an 80 c10 sb. I was thinking 78/75 billet wheel from btr. Btr stage 3 turbo cam. (What ever springs go with cam)
Gap rings, head studs, ls9 gaskets, stock computer, Eli live . 80 lbs injectors, 93 w/meth. Can I achieve this with these parts or is there a better cam/ turbo choice (for around the same $$)?
Started my turbo build here with similar goals. Check it out.
https://ls1tech.com/forums/multimedi...s-vids-17.html
Not sure on intake yet. I'm not stuck on cam, just throwing it out there. Really looking for a recipe that works, hence the thread. I don't want to make the same mistakes I did building my car, buying things 2-3 times till I found things that worked. Lol. This is a street truck/drag strip on week ends .
800hp on gen3 rod is most likely never gonna happen. Just buy a 150 dollar set of gen4 rods and pistons since you are planning on having the pistons out to gap the rings. Then basically any stage 2 turbo cam and an s480. Thats ur basic 800hp build. 80s and meth is doable but why not spend the extra 100 bucks or so and just buy bosch 210s and run e85. Then you will have room to grow in the future.
Yes I agree. Any stage 2 turbo cam China or borg s480 a good fuel system with 210's. Gen 4 rods a must. If ur gapping rings gap them once on gen 4's and it will last awhile.
Basically what everyone else said. Stage 1 or stage 2 cam from LJMS or BTR, stock truck intake, 80lb injectors for gas (127lb for e85) and a T6 borg warner s480 96mm exhaust 1.32 a/r. Tried and true combo with room to grow. Set up the hot side for the borg and when you are ready for more power with a better engine you can upgrade to a s485 or something that makes 1200 rwhp.
Heres my buddies stock bottom end gen 4 5.3 with a s485, he now has a GT55 94mm on it. Hes ran it hard all year lots of passes.
If you are set on 93 and meth I feel like you need to go to a larger injector then 80s. They are about maxed out at 800 tire unless ur just hammering with meth.
It's my buddy's truck. He just wants something he can take out on the weekend and beat on. We have always wanted to turbo something . He wants it faster than my 6.0/whippled cutlass. Something we can drive to the track, run 10s and drive home with Ac on. Prob gonna tear motor down, new cam bearings, gen 4 piston /rods etc... turbo cam, s480 see where we end up.
Ok so update. What's a good piston /rod combo for my goals . We are going to drop block off at machine shop and have them build short block
. Hot tank, new rods/ pistons, gap rings
Cam bearings etc. I saw some new gen 4 rods w/ Arp bolts for $325 on eBay. Should I consider these? Or is there a better option?
