Doesn't look like I got much done but had to do it all by hand due to the bars and uneven services. Should get it all painted this weekend so I can get motor and tranny in.
didnt. Clear it for easier touch up's it turned out pretty good. Pops with the silver and will look at home with the powdercoat and polish.1/3 of the way done with paint. Going to get motor and tranny etc in before I do anymore. Can stand the sanding lol
Finally got the front plate and water pump on. I had to drill and put timeserts in all 6 holes because they were stripped when the chassis builder was making the plate. I ended up putting in studs which made it easy to keep everything lined up.
I had to cut the fins off the alternator fan so they wouldn't hit the bracket so I decided the polish the pulley and fan.
The gold didnt match everything else so I had to do something. Only took about 20min and it was damn nice.i could get the gold inside the pulley but the shadow from the shaft and nut hides it and the light yellow in the center of the fan is covered by the pulley.
I had to cut the fines off the alternator fast so they would hit the bracket so I decided the polish the pulley and fan.
While it looks nice, I’m sure you know the fins help cool the alternator?
Well I got all my rear suspension powdercoated. Turned out great, but they forgot to tap off the threads on the fill hole. It's too big for a die.....so what can I do to get it off. Will a really strong paint remover work?
like 01red you can use a wire wheel. brass is less abrasive but if it doesnt then work a normal steel wire wheel will work just be super careful and not slip cause it will get away from you quick
Well not much of an update. Still doing the paint thing. Still hating it. Takes too much time to just prep. I am changing the interior to flat black so another month of taping.
It takes a good month for me to get 30hrs of car time Work is tough right now.
wrapped everything with paper so it took way longer.
