Junk nittos, from dig
Old Oct 2, 2017 | 10:22 PM
  #81
LilJayV10's Avatar
Originally Posted by 3 window
Car’s heavier than you think. It’s a beast. Well thought out and attention to detail is why it does what it does.
Most good builds are. Much respect.
Old Oct 3, 2017 | 08:22 AM
  #82
rotary1307cc's Avatar
Sorry hadn't been back on here. As to power I don't know.
At 7500rpm on 25psi it is using 1050lb/hr on e80ish
Originally Posted by neverstop
hey rotary, any rough guess at current whp and weight in lbs? going through your other threads and not real clear where the setup is today.
The car is right around 3250lbs with me in it depending on fuel load
The setup is a 390inch LSX based. It is a winberg crank,Oliver rod, racetec piston. With the tfs 255 LS3 head on top. 1.80glide, 3.27 8.8 in back. 94mm gt55 turbo
Originally Posted by nocooler
Any chance you could let us know how you are utilizing you I/o on the hp box?
What exactly you looking to know
Right now
Inputs
Dome
Coolant pressure
Tbrake
(Saved for speed or flex fuel)
Outputs
+Solenoid
- Solenoid
2nd pump
PWM cooling fan
good point on 900lbs/hr.
just in big rough numbers that seems like ~1500hp and that car probably weighs 2900lbs I'd guess. So gnarly. I love the videos of the dog riding shotgun at 150mph all non chalant too. LOL
The dog has learned to accept it. She knows that is the only way to the farm so hops in haha
Thanks! But you are exaggerating!
Old Oct 3, 2017 | 10:20 AM
  #83
3 window's Avatar
All the data you’ve collected and changes you’ve made based on that data shows you know what the hell you’re doing and how to get the most out of what you have. And I have a feeling that will continue. No exaggeration here friend.
Old Oct 5, 2017 | 03:42 PM
  #84
TrickFlowTech's Avatar
LS1Tech Sponsor
Nice work!
__________________
Old May 15, 2019 | 04:14 PM
  #85
Alright add to this some with updates
Big change is I have went from a HP to a dominator, and have front and rear wheel speeds and my own TC
This has made the car almost impossible to mess up a run. You could throw anyone it it and they could flat foot it at any speed no worries
The TC obviously won't make you any faster, but crazy consistent and hard to muff
The setup is built to limit and clamp a set slip, and it does this very well
On my car with the nitto if you can keep the slip percentage around 10 or less..... the acceleration really doesn't suffer at all, beyond that, yes
Here is example of it riding the TC, can see all the important information and how well it works
And just for fun, not much overall boost but aggressive enough curve. The road was damp one morning. I was WOT all they way through that, couldn't believe it could do that
Here is where I got to on the dig stuff, I could get better if I put more power in on top, but fairly happy
Accomplished just like this example. No burnout just stop, brake and go
This was to a bit over 120 by itself,
After i had the dig sorted well I layed off it so I wasn't on the 2step and tbrake every single time, so went back to optimizing 60-130
This is about all the car has in it on the current tire. I am limiting the power all the way till just over 120mph here, 24psi
60-100 is the hard part for a rwd setup, that is the key
I could put more power in up top but nothing to really be gained in that last blip
The G trace tells the story. It's the key. Power is building the whole time to hold the G flat and once boost peaks is when it starts dropping
At the end of the year I put some more boost in up top for a couple hits because I really wanted a 2 second 100-150 on the street. 26psi from 125 on
Ok here is something interesting as well I did for fun
The car was completely sorted and at a 3.90 tune (100% chance of the nittos doing it every time)
I had a set of fresh Mickey etr, same size
I bolted them on everything else identical....
I the TC could barely keep the car inline, black tracking..... 4.2 was the best they could yield and by 3 hits they where worthless from the balling
Here is the condition after 3 hits.
Yeah huge rambling post sorry, lol
Old May 15, 2019 | 04:23 PM
  #86
Should mention too that I have some friends with big power 1300-1500whp, that are setup similar now and are also into the 3s on the street with the nittos. One was a huge Mickey pro guy and laughed at nittos. And the pros wouldn't touch what the car does now. And no buying tires monthly
Old May 15, 2019 | 05:28 PM
  #87
LilJayV10's Avatar
Are you using Holley's new TC box or did you make your own Advanved ICF?
Old May 15, 2019 | 06:02 PM
  #88
stoverz28's Avatar
I always tell my buddies I race with to get a vbox to help them hook and apply power but no one ever listens.
That said, I got a bit over 5000 hard miles out of my last set of Nittos. Hooked like trash when the centers started to wear, but were great up until then. New set was mounted yesterday, can't wait to try them out.
Old May 15, 2019 | 08:09 PM
  #89
Yeah my own , advanced table and pwm
Yeah they would see if they ever used it. Through nittos for me get better through more they wear and the harder they freeze lol. Best for me when they are scabs lol
Old May 15, 2019 | 08:50 PM
  #90
MY_2K_Z's Avatar
What size nitto do you run? I thought about trying the 325/50r15 on mine. I'd love to get some miles on a set of tires. I got 1000 out of my mickeys and like 500 out of the Hoosiers. Literally a waste of money!
Old May 16, 2019 | 07:30 AM
  #91
408GT's Avatar
I believe he runs 275/50's. Very impressive car for sure.
Old May 16, 2019 | 11:01 AM
  #92
3 window's Avatar
Originally Posted by 408gt
i believe he runs 275/50's. Very impressive car for sure.
Yes 275/50
Old May 16, 2019 | 05:41 PM
  #93
Yeah I run the 275/50-15. The 26"
Old May 16, 2019 | 06:53 PM
  #94
MY_2K_Z's Avatar
Just realized I already asked that question in this thread 2 years ago lol. I might as well try them. Worst case I hate um and switch back in a couple months which is how long mickeys last anyways.
Old May 16, 2019 | 07:04 PM
  #95
You can send them to me!
Old May 16, 2019 | 09:01 PM
  #96
Bad Apache's Avatar
Thanks for posting this up! Great info here. Appreciate you spending the time and money then sharing what you learned. You keep costing me money on changes/upgrades, lol
Old May 17, 2019 | 10:58 PM
  #97
BigBadWhitey's Avatar
Question for you: at my local track we aren't allowed to use aftermarket TC boxes or anything like that aside from a 2step. I've got a parocharged m6 car. Do you still recommend the nittos? I read somewhere you said they dont like being shocked, would they be okay from a dig without fancy computer work? Or should i grab something else?
Old May 17, 2019 | 11:50 PM
  #98
MY_2K_Z's Avatar
Bracket racing or what?
Old May 18, 2019 | 06:24 AM
  #99
Launch's Avatar
Get Hoosier QTP bias ply
