Junk nittos, from dig
Old Aug 22, 2017 | 07:15 AM
rotary1307cc's Avatar
Default Junk nittos, from dig
Just sharing because everyone hates on these tires
Traction is always consistent because they are hard enough to never ball and they last 10x the Mickey's
Old Aug 22, 2017 | 07:18 AM
JoeNova's Avatar
Restricted User
555r almost killed me a couple of months ago.
N/A 6.0 with a mild cam, nothing fancy at all. They broke loose on the downshift and the car went sideways. Didn't end well. The car would spin them at 35% throttle from a stop. You have *****, sir.
Old Aug 22, 2017 | 07:21 AM
Here is one that built to 25psi in high, yes I lifted early,
Old Aug 22, 2017 | 07:22 AM
The tires are gems if u know how to use them
Old Aug 22, 2017 | 07:26 AM
JoeNova's Avatar
Restricted User
I was out street tuning. I guess it didn't help they were on a 20" wheel, but it wasn't my car.
It would skate around from a stop at part throttle almost as bad as my corvette. The shock of a 3-2 downshift through the auto trans broke the tires loose. I ended up in a guard rail.
Old Aug 22, 2017 | 08:45 AM
RedRocketZ28's Avatar
I have a set I use to drive around town or to the track. Not making anywhere near the power you are but I really like them. Spirited runs are never an issue.
Old Aug 22, 2017 | 10:01 AM
3 window's Avatar
I think the nittos get a bad wrap because most guys run a shorter sidewall than say a 275/60 and to me that's comparing apples and oranges. Maybe the shorter profiles don't work as well because there's now sidewall there, and what is there is so short, it doesn't perform well. They obviously can work, the vbox shows a 60' time of 1.80 on the street, no burnout, no prep.
Old Aug 22, 2017 | 10:16 AM
408GT's Avatar
That's pretty impressive for a dig on the street. How much boost was it leaving on and how much ramp?
Old Aug 22, 2017 | 10:32 AM
rkupon1's Avatar
I had a similiar situation with the 555r. 705whp, even if the ground was cool, or if sumone emptied thier coffee on the road 2days ago...i had no luck with them on the Lightning. Others luvd em...
Cool video none the less. Care to share any info about your boost control/strategy?
Old Aug 22, 2017 | 10:41 AM
3 window's Avatar
Aggressive enough to go just shy of 130 in the 1/8! Haha
Old Aug 22, 2017 | 01:04 PM
Forcefed86's Avatar
Not to take away from the nitto runs, those are darn impressive on asphalt IMO.
Power application is pretty huge. The true radial class is tarting to take off. Guys are trapping 150's-160's at my podunk track on 275 coopers. Believe skinnies went 9.0 @ 163 a year ago or so on 275 pep boys M&S futura's! lol. (non-prep'd track)
https://www.youtube.com/watch?v=zy-c...ature=youtu.be
Old Aug 22, 2017 | 02:06 PM
Track still different than clean asphalt
I do think I can get a couple tenths in the 60ft once I mess with the brake and 2step. That is where I need to work
My G trace is perfect from 10mph on. Table top flat .8-.9 g from 10mph to 110mph
That is the key to these tires and my most useful tool. Hit and hold the peak target G the tire will hold. And absolutely do not shock them
The shift is the tricky spot but I have that down
Old Aug 22, 2017 | 02:09 PM
I will share a deal later.
It was leaving on 3600rpm, .5psi boost
The strategy is boost per RPM... Per gear. It is amazing
Old Aug 22, 2017 | 02:25 PM
Game ova's Avatar
That trap speed is retarded high. Definitely well into the 8 second zone.
Old Aug 22, 2017 | 02:29 PM
408GT's Avatar
Nice can't wait to see it.
Old Aug 22, 2017 | 02:50 PM
Forcefed86's Avatar
I hear ya, the old airports they race on here are total crap compared to a “no-prep” event at the track.
Would be super cool if they could integrate the G-meter into the traction control software and adjust power accordingly. Seems like an easier method than playing with wheel speeds.
Old Aug 22, 2017 | 08:32 PM
rkupon1's Avatar
Awesum!!! I just pickd up the Holley Dominator. I ve got so much to learn, but i believe its all in there
Old Aug 22, 2017 | 08:33 PM
rkupon1's Avatar
LOSLS2 could prolly figure it out n make it a reality...
Old Aug 22, 2017 | 09:10 PM
Yeah that 9.5 one is upper 160 power, I usually pickup around 15-16mph from the 1000ft
Here is a 22lb hit
Old Aug 22, 2017 | 09:19 PM
Game ova's Avatar
Here is a 22lb hit
Are you rolling into it? I watched the video, and the ET vs trap is WAY off. I see that the car didn't spin the least bit, I'm confused.
