Junk nittos, from dig
Old Aug 23, 2017 | 03:21 PM
  #41
rotary1307cc's Avatar
Originally Posted by MY_2K_Z
This is exactly what I was just explaining to a buddy of mine and then I read this! I really don't like my et streets for the street. They are completely worthless, what size are you running?
I am running a 275/50-15
Old Aug 23, 2017 | 03:26 PM
  #42
Originally Posted by 408GT
I know what you're saying about the Mickey Thompsons tearing up really bad. Unbelievable how fast they wore out! Because of reading your posts over the years, I've switched to the Nitto for the street and they last a lot longer.
So not even a small burnout at the track to clean the tires off? I've been a 1.5 on a NT05R 315/35/17 and have a race this weekend where I'll be running the 315's.
I honestly can't help you on the track. I never go and if I did I'd be on the slicks or Mickey radials
The nittos do not want to be shocked, I don't care if it's on the launch or the shift
On the street I am footbraking and keeping the suspension preloaded and then leaving
That is as much as I can hold it before i can't hold the rear axle with the service brakes
I feel it would hold alot more on the leave if I could clamp more
I will be testing with the transbrake and 2step here shortly and will know more. But I don't think they will like the jolt and shock of the suspension with the transbrake
Old Aug 23, 2017 | 09:56 PM
  #43
3 window's Avatar
"Z"box FTW!!!
Old Aug 23, 2017 | 11:24 PM
  #44
Formula934's Avatar
The 555rs are not a bad street tire if they're coupled with the appropriate suspension. Im using my 275/40/17s with a mosier 8.8 eaton trutrac and 3.42 gears with over 600rwhp on my Ws6. Although i get some spin at the top of first, it dead hooks in 2nd.
Old Aug 24, 2017 | 08:11 AM
  #45
Only ERO's's Avatar
I am still laughing that you got banned from FB: Boosted LSX for starting this same thread there. What a bunch of pussies their admins are. Straight snowflakes! They obviously don't realize good information when they see it.
Old Aug 24, 2017 | 08:28 AM
  #46
Originally Posted by 3 window
"Z"box FTW!!!
I'm using it lol
Yeah I'm not quite sure about that one lol. I mean I am a dick but that wasn't the point of it lol
Old Aug 24, 2017 | 08:54 AM
  #47
Game ova's Avatar
Originally Posted by rotary1307cc
I'm using it lol
They banned you for you showing everyone that a certain tire works for your setup??? Or was it for filming yourself breaking the law? And to be clear, I'm by NO means judging. I think we've all been triple digits at various times on the street.
Old Aug 24, 2017 | 09:17 AM
  #48
Only ERO's's Avatar
If you try to get those nuthuggers over there to look outside of their tunnel vision, their feelings get hurt. They aren't open to any disputes. They have their ideas, and that is all there is.
Old Aug 24, 2017 | 10:35 AM
  #49
neverstop's Avatar
Some guys legitimately interested so I will put together a good post, it should be interesting to you. I promise
awesome. will be really cool to hear more details on the setup and how it all works together. holding ~1G of acceleration from 0-100mph on the street is phokin crazy
I'm ~900whp c6 vette with 6 speed so different setup, but I always just assumed I'd need a 4wd car to hit <4s on the street 60-130. 3.1 seconds 100-150mph is just insane. really impressive stuff man. clearly took a lot of thought and work to get to that level.
Old Aug 24, 2017 | 11:24 AM
  #50
Sounds like you know something about being banned over there looool
Thanks alot. Yes.lots of time. Haha. I have over 400 vbox files... And 2 to 3 hits per file.but it finally came together
It's definitely why I know the gtr and ttg stuff is absolutely insane what they can do. Like crushing lol
Old Aug 24, 2017 | 12:19 PM
  #51
Alright may ramble a but will get it across
I'm kinda on a top fuel approach,
I know that these tires can hold around .9g of acceleration on the asphalt and not get into trouble
Get above that and poof... Stay below.... No problems
So the goal is to hold that target .9g as stable and as far as I can until I don't have enough power to deliver .9g as speed increases
So I am limiting power up to around 110 and then power limited after that.
So here we have an 8.40 pass track from Josh (ero)
Take note of the G curve when we have unlimited traction and full power in right off the launch
Now here is my street pass.... Remember what I said about trying to hold .9g. this is very similar acceleration out the back as joshes pass above
Now look at that g curve.... And here is the data log from that hit...
You would never think that boost delivery would deliver that G curve.....
The shift is the trickiest part by far.... To not shock the tire but not get a lul in acceleration aswell
This is what I fought with the ams1000 and why boost vs speed and boost vs time won't work.
That delivery of boost on the shift has to be at the exact right time and very precise
This is why the holley finally let me do what I need
I use boost per RPM and each gear has its own table
What I am really doing is controlling how I get on the converter
My settings don't change if I go from a dig or if I go from a 50mph roll.... And the car will run almost identical 60-130s either way
I don't have a wheel speed nor DS speed on the car period right now
With the boost delivery sorted this well by adding TC which I am in the process of it should be almost stupid consistent
Old Aug 24, 2017 | 12:59 PM
  #52
stoverz28's Avatar
So when the rpm drops from the shift the holley automatically switches tables?
Thanks for posting btw!
Old Aug 24, 2017 | 01:14 PM
  #53
Yes you are correct. No input is needed. I am doing this all on a holley HP
Here is good clear snap shot. You can see my target boost which is coming from the tables... And the actual boost. And dome pressure is up there
This is actually the 9.54 hit, 25psi in high. I did have to blip that one right after the leave once
Old Aug 24, 2017 | 01:51 PM
  #54
3 window's Avatar
That target boost/actual boost trace is sick!
Old Aug 24, 2017 | 02:23 PM
  #55
Only ERO's's Avatar
That's not possible!!!
Old Aug 24, 2017 | 06:51 PM
  #56
JAX04's Avatar
You working on adding the Davis box? or something of your own design?
  #57
neverstop's Avatar
thanks for posting. that's really wild. I did not realize Holley had that functionality like that on a per gear basis. also did not realize that an 8 second run at the track meant almost 2g at launch. really cool stuff, I'm sure that took ages to get so perfectly dialed in like that.
do you have a build thread anywhere with more details on the car? (weight, whp, fuel, motor setup, etc)
would be interesting to see the difference of these numbers on the street vs. at the track too with more grip
Old Aug 24, 2017 | 07:25 PM
  #58
truckdoug's Avatar
damn impressive!
dumb question: what pressure do you run in these? I have the same tires and i'm trying to make them work for me.
Old Aug 24, 2017 | 08:24 PM
  #59
stoverz28's Avatar
He has an extremely long and detailed build thread over on norotors.com, just search zbrown.
So how do you reset the tables back to the base?
Old Aug 24, 2017 | 09:15 PM
  #60
Only ERO's's Avatar
I believe this was my timeslip from that V-box data.
