Billet 7875 Results thread
hopefully next year I can get the sixty down to a respectable 1.60' and run half track passes since I dont have a bar/cage/etc..
we did a test on my buddys backhalf Camaro . with a 2005 5.3 with triple 12 cam , 400th, 3.73 gear and 31.5 by 12 slick leaving at 12 psi and running 20.5 psi max it ran
9.40 at 141 mph with a cast on3 78/75.
swapped to a borg 80mm with 83 mm turbine 76mm exducer and t4 1.25 housing it ran 9.31 at 142 mph all else being the same. spool was much slower due to borg being bigger heavier parts. but iat did drop about 25 degrees.
I'm sure turning them up more we whould have seen a bigger difference but for the money a 78/75 is a good turbo.
I'm not sure the bilit helps much as they already spool fast and I think the turbine wheel and housing are the limiting factors.
When I called BTR awhile back and told them my setup/goals which is a 5.3 and a HSP 78/75 with a goal of 600-700hp they said the Stage 1 222/227 .602"/.598" 113+3 would work the best. I would imagine with that BTR Stage 3 cam 230/235 .609"/.610" 114+4 it would depend on your setup and how much power you want.
The result is an earlier exhaust valve opening (54.5 BBDC) to start the blow down process sooner due to high back pressure from the 75mm 0.96 turbine assembly. This helps reduce pumping losses through the exhaust side and starts spooling the turbo sooner. Additionally, this results in -6 degrees overlap which is needed with high exhaust back pressure setups. And my intake valve close occurs at 38.5 ABDC which gives a nice dynamic CR and good bottom end torque and turbo spool.
Hope that helps someone
-John
Roastin Performance
i took every cam i could find recommended for the 7875 and plugged it into the cam motion cam timer. very little variation on that theme of -6* overlap. most were within a degree or two.
