Billet 7875 Results thread
Old Oct 25, 2018 | 03:19 PM
  #61
jdyer00's Avatar
98 Camaro LQ4 6.0 huron speed v1 kit 7875 turbo LJMS stage 2 turbo cam 18 psi and 12* 80# Dekas springs and trunion upgrades stock bottom end on pump gas/meth
Old Nov 17, 2018 | 03:26 PM
  #62
Kfxguy's Avatar
What is the advantage of the billet 7875 over the cast wheel 7875? Anyone swapped from one to the other? Is the billet worth the extra money?
Old Nov 19, 2018 | 07:37 PM
  #63
Mavn's Avatar
"I MAID THEESE"
I had the billet 7875 . Stock 4.8 no cam nothing . Stoxk 80e . I made 670 rwhp on 19# .
my buddy had the cast on his heads/ boost cam 5.7l ls1 . He made 570 on 12# . In my opinion . The billet is was more efficient
Old Nov 19, 2018 | 08:07 PM
  #64
Kfxguy's Avatar
maybe. But here’s what I figured up. Without knowing either motors hp before the turbo, I estimated the hp gain at 30hp per psi. His motor would have made about 240hp more on 19lbs (remember, estimate because we all know that too many variables and his turbo may have not supported that much hp). So that would have put him in the 800hp range. The billet is supposed to be more efficient and spool faster and be capable of more hp, but I wish someone had the cast, ran their car, put a billet on with no other changes and ran or dynonit again. That would be a true testament.
Old Nov 20, 2018 | 11:34 AM
  #65
01ssreda4's Avatar
No dyno numbers, but i finally got this one running and tuned. With the Huron speed kit, and a 7lb spring it makes 11.5ish psi. It goes into positive boost at 2500rpms (which i thought was good) Pulls real nice as is, timing is between 17-19 on pump e70, afr is 11.2.
Old Nov 20, 2018 | 01:31 PM
  #66
Mavn's Avatar
"I MAID THEESE"
https://www.youtube.com/watch?v=EmnO8pPmXow
SBE ls1?
Old Nov 20, 2018 | 02:13 PM
  #67
01ssreda4's Avatar
SBE ls1?
L33 5.3, 4l80e, Moser 9 inch
https://ls1tech.com/forums/forced-in...-75-build.html
Old Nov 20, 2018 | 02:15 PM
  #68
Game ova's Avatar
Hope it was the converter, but that high gear sounds very suspect.
Old Nov 20, 2018 | 02:21 PM
  #69
01ssreda4's Avatar
do what? you lost me
Let me clarify, the 80e tuning isn't/wasn't done there. I didn't tune the manual tables, I had it in 2nd coming over the hill, because i wasn't 100% throttle the ****** shifted to third before i moved the shifter. It's in a table in the tune I just haven't corrected it yet, if that's what you're referring to.
Old Nov 20, 2018 | 02:23 PM
  #70
Game ova's Avatar
I watched the video, sounded like on the 2-3 shift, the transmission was slipping. Either that, or it was riding the converter. RPM sounded like it shot up.
Old Nov 20, 2018 | 02:49 PM
  #71
01ssreda4's Avatar
Edited my comment, you are correct
Old Nov 20, 2018 | 08:42 PM
  #72
2kgtp's Avatar
I have a cast on3 78/75 and have gone 9.67@146 im my 3750~ weight Camaro on 20#’s locking my converter.
Old Nov 25, 2018 | 02:51 PM
  #73
fegoins's Avatar
4.8, BTR Stage 2, BTR springs, 7875 VS Billet, 4l80e w/HD kit, Circle D single unlocked, 8.8 w/3:73 gears, A2A, E85. 93 Mustang, 3400lbs with driver. Best run to date 10.30 @ 135 with a 1.6 60', 15psi 1rst and 2nd, 10psi 3rd to keep my speed at 135 or less (6pt no cage). Dyno soon to tune to 20psi.
https://youtu.be/q7QwN61oFPE
Old Dec 6, 2018 | 11:56 PM
  #74
BlkBird2000's Avatar
6.0 LQ4 7875, tick stg1 turbo cam, 317s, 3” down pipe with 3” cutout, t-56 car made 711/779 on 17 psi. 530/570 on 10 psi. It makes peak boost around 5,300 rpm and drops off after that.
Old Dec 8, 2018 | 03:02 AM
  #75
4EyedTurd1's Avatar
Originally Posted by BlkBird2000
6.0 LQ4 7875, tick stg1 turbo cam, 317s, 3” down pipe with 3” cutout, t-56 car made 711/779 on 17 psi. 530/570 on 10 psi. It makes peak boost around 5,300 rpm and drops off after that. https://youtu.be/QN8B6BRMJ4U
Nice numbers, I’m curious if you have it in 4th gear and nail the gas at what rpm does it start making boost? Is that the cast or Billet 7875?
Old Dec 8, 2018 | 09:10 AM
  #76
Kfxguy's Avatar
if I do that in any gear, boost take a split second to hit. If you want I can take a video of it. Just tell me what gear and rpm you want me at. Mines an auto tho.
Old Dec 8, 2018 | 12:48 PM
  #77
4EyedTurd1's Avatar
I ask BlkBird2000 since he has a 6.0
Old Dec 8, 2018 | 12:58 PM
  #78
Kfxguy's Avatar
Cool
well excuse me lol. I have a 5.7 and I figured it would be relevant because it would turn on faster with a 6 liter vs 5.7. I’ll refrain trying to help next time. I actually went did a video but I won’t waste my time posting it.
Old Dec 8, 2018 | 04:54 PM
  #79
4EyedTurd1's Avatar
Well....go ahead and post it.
Old Dec 9, 2018 | 01:43 PM
  #80
Kfxguy's Avatar
By Brett Foote | 2026-06-04 05:00:17
