Boosted ERL 434
Or is a regular Callie's forged crank do u have six bolt heads ?
looking forward to seeing the f1a94 results though. not sure why we don't see more builds with that blower. looks like a monster on the numbers i've seen on other platforms
The only issues I've heard about with the ERL stuff was the dry sleeves would possibly drop a sleeve. The wet sleeve stuff is pretty much indestructible.
We spin a super-deck north of 8500 all the time with the baby 88mm on it. Go through the 1/8th around 7500-8200 depending on what turbo is on it.
There are other options:
http://www.raceenginedevelopment.com
Andrew
Can make a decent amount of power and RPM with hydraulic stuff, but I'd be watching radiator/cooling system pressure for sure with a 4 bolt and that big of a bore.
They swapped to a LSX block and haven't had an issue since.
We change the head gaskets when they start to leak.. usually in the 40-50 pass range.
We shoved 33psi into Ray's 2 weeks ago, went 4.37, .44, .45, .53 (not in that order)on a fresh set.
That blower is badass and would make some great power on different block. I have some custom diamond pistons for boost that are 4.125 that I'm selling since I'm going with a different setup.
Don't neee crazy cubes to make power out of these setups.
The car was street raced and tracked raced at the time, I dk if that makes a difference.
