Quench area with boosted engines.
The general consensus is (in a power adder world) a larger quench opens up the tuning window. Or maybe a better way to say it is....gives you some "cushion" on hitting the tune up. See many top builders say 0.075" to 0.100" for big power combos. (My boosted short block will have only 0.079").
So piston compression height will need to be designed in. And given the piston in the hole as well as the gasket, careful consideration for desired SRC will need to be calc'ed.
It's a topic not discussed here much but info can be found on YB or speedtalk.
I'm always suprised to see these guys zero decking or even pushing the piston out of the hole with big boosted combos. Often wonder what the approach was when designing their short block.
Good luck on the combo...
How do a large quench affect the performance of a boosted engine? will it be more prone to detonation? will it have any flame propogation issue? And when you said it will give me more "window" to tune, do you mean that I can reach a leaner mixture and/or rise the timing more comfortably?
I would use a Felpro 1041 HG AND a "proud" piston deck of .007" depending on MAX RPM AND block material AL/Iron ?
I would fit MY stud kit.
I am doing the same (LSA) order for a RaceTec Forged Piston.
My "tech" is to reduce the Dish Bore Diameter AND add depth for the correct Squish, the correct CR.
The LSA AL block will expand (grow) more than an Iron block.
The lower CR of a SC engine LOVES Squish as this feature produces Swirl with results in MUCH better Throttled Performance.
Would you like a RaceTec Forged Piston ?
Lance
Tight quench speeds up the cumbustion process...which is what you want for a n/a combo. The quicker the flame front the less ingintion advance you need. Less ignition advance means less BTDC struggle which = more hp
But..in a power adder world, your trying to slow down the burn rate, in an attempt to control the chaos. And by reducing the quench it slows the burn rate (because the mixture is spread out in the chamber, tight quench forces the mixture away from the edges and towards the center of the chamber, thus speeding up the burn)...because your effectively killing the efficiency of the chamber...or at least hurt it.
Same thing as softening the chambers...its an attempt at killing the efficient chamber.
To answer some of your questions....
The performance gain will come in the form of a well controlled burn at any boost level.
typically the tighter the quench the greater risk of detonation (because your speeding up the burn).
Flame propagation will be somewhat compromised by nature of the beast.
More window....as in you won't melt your combo to the ground if the tune up is a tad off...or the da swings 500'. The AFR should be targeted regardless of quench.
Thanks...just my simple understanding
....EDIT......but I have learned over the years...people can tear up anything. So all of this is to be taken with a grain of salt.
