Aem wideband 30-4110 / hptuners - erratic a/f numbers all over on scanner
im sure this is a basic question but I haven't been able to find what I'm looking for.
I have the 2 hooked up and while recording the scanner shows the a/f numbers bouncing all over.
How do I resolve this to verify they read the same?
I've researched this for a while now and can't find a solution.
My tuner says the figure should stay solid like the gauge but they don't use the aem wideband.
I originally had the wideband going to terminal 1 on the EIO and I've grounded 5 to a bolt under the shifter. Last night I grounded terminal 6, ran a new ground from the battery to the grounding point at the shifter, ran another ground from the aem harness to the same location under the shifter. Still having the same issue.
Im completely new to hp tuners and trying to get this going. Any help would be greatly appreciated.
I used the info already provided by hptuners for this wideband. trying to get it to have a solid number so I can adjust the offset if it needs it which, from what I'm guessing, it does.
Does HPT not have a digital input like EFI Live? Gets rid of having to mess with offset/ground differences. If not, I'd also check the grounding in the system, i.e. do all the factory ground locations have paint under the ring lug or bare metal and is there a solid ground from chassis to block. I've helped a couple cars by adding a better gauge ground from chassis to block.
How erratic are we talking here? 14.58-14.62 or 13.22- 16.88?
My only wideband is the innovate scg1 i believe, wideband and boost controller together, and my readings are nearly the same. 1 thing obvious is the gauge reads 14.7 where the scanner will show 14.75. The scanner has an extra decimal place, which i believe can be changed. I did have to play with the settings using the tuning schools wideband offset sheet.
I am looking for a wideband to use between other vehicles and have heard great things about the aem
the sensor is approx 10" past the turbo (s475) with a full exhaust. Cutout is under driver and is closed.
I have all vbands on turbo system sealed with rtv sealant except the the turbo discharge. I'll seal it up and give it a try.
I hope I attached my log correctly. It averages 9.62 across all the points.
It ranged from 8.84 to 11.32 as shown in the log.
Is it normal for the numbers to be all over like this?
Do I just use 9.62 to adjust it up to 11.6 or whatever the gauge would say?
I have an LM-2 and after having issues with it I bought the aem as everyone seems real happy with it plus the cost helped. Now I think I may be regretting it.
