Nova going in under the knife
Old Jan 18, 2018 | 01:54 PM
  #61
forcd ind's Avatar
Forgot to add pics
Attached Thumbnails Nova going in under the knife-0118181012.jpg   Nova going in under the knife-0118181241.jpg   Nova going in under the knife-0118181241a.jpg
Old Jan 19, 2018 | 09:14 AM
  #62
jasonsnova's Avatar
coming along nicely....i couldn' get truck manifolds to clear with power steering on my nova either , I ended up using cx racing corvette headers they fit mint.
Old Jan 20, 2018 | 10:08 AM
  #63
forcd ind's Avatar
Painted the new engine, hopefully install it tomorrow, be nice to actually bolt on something that stays bolted on, lol
Old Jan 21, 2018 | 12:42 PM
  #64
rkupon1's Avatar
Wow, that came out great!
Old Jan 21, 2018 | 12:57 PM
  #65
Modchevelle's Avatar
Old Jan 21, 2018 | 01:00 PM
  #66
forcd ind's Avatar
Got the engine back in, now I can make some progress-minor problem, I am using a plastic mock up 4L80E, I forgot the rear cover bolts hit the thick part of the case, so I cant bolt it up tight to the engine. Prob rather have a real case in there anyway just to make sure nothing changes after mocking it all up. Prob just rem the bolts temp. until I gut a spare case, to heavy trying to wrestle one in comp. w/o being on the lift.
Attached Thumbnails Nova going in under the knife-0121180922.jpg   Nova going in under the knife-0121181149.jpg   Nova going in under the knife-0121181213.jpg
Old Jan 26, 2018 | 05:32 PM
  #67
forcd ind's Avatar
A little more progress, got the lower control arms, installed the springs-not my fav. job, a whole lot of 4 letter words needed to get it done., lol.
Anyway, its back on the ground, so now I can plumb the intercooler since I know where the wheel is in relation to the wheel well-hopefully there's enough room. Got my shorter pushrods, so I can reduce the preload, the intake valve was closer to the piston than I liked, this will give me a little extra. Started on the 4l80E again, another of not one of my fav. jobs, lol. Painted my brackets for the alt, PS, painted the PS pump, trying to figure out how to clean up the ugly alt. Next i'll rem. the front seat, start installing the Holley HP, the trans controller, run wires back for the pumps, etc.
Attached Thumbnails Nova going in under the knife-0123181354.jpg   Nova going in under the knife-0121181532.jpg   Nova going in under the knife-1516554773658.jpg
Old Jan 31, 2018 | 03:34 PM
  #68
forcd ind's Avatar
Took the seats and rubber mat out to run wires, cleanest floors I have seen in a while, lol. Started on the IC'er, got one side done, waiting on parts for to finish. Its a Procharger IC'er, they rate it for 825 HP, I have used one before, works OK-it was $200 shipped, so why not, lol. Got the Griffin radiator, now I can meas up for hoses, get some fans. Finished up the mount for the fuel pumps, filters. Made up a mount for the Holley 3.5 screen, and the trans controller. Maybe tomorrow I will move it onto the lift, tired of laying on my back, lol.
Attached Thumbnails Nova going in under the knife-0128181309.jpg   Nova going in under the knife-0129181145.jpg   Nova going in under the knife-0131181135.jpg
Old Jan 31, 2018 | 04:47 PM
  #69
vettewreck's Avatar
Here's my '69 Nova with a 6.0 cammed/4L60 swapped I just sold recently. I miss it!
Attached Thumbnails Nova going in under the knife-00c0c_2yhqby1uq7g_600x450.jpg   Nova going in under the knife-20170626_125737.jpg   Nova going in under the knife-00t0t_eh74vq36pzh_600x450.jpg   Nova going in under the knife-img_62621.jpg   Nova going in under the knife-20170811_100411.jpg
Old Feb 2, 2018 | 03:04 PM
  #70
rkupon1's Avatar
Makn good progress. Looks clean n tidy upfront
Old Feb 8, 2018 | 02:19 PM
  #71
forcd ind's Avatar
Making a little more progress, finished the brake lines, bought a couple radiator hoses that looked close, the bottom one fit with minor trimming, the top on I said the hell with it and cut it in half. A little trimming and using a 1 1/4" coupler and it will work fine. Pretty much the rear fuel setup is done, couple 180's and a 90 deg to the filter, but with #12 stuff should be no rest. Hopefully tomorrow the IC'er plumbing will be done. Having to stop and paint every part is a PITA, but worth it in the end. Still undecided on whether to run #8 or #10 for the feed, prob 10 is overkill for what I am doing, i'll work on that.
Attached Thumbnails Nova going in under the knife-0208181400.jpg   Nova going in under the knife-0208181401.jpg   Nova going in under the knife-0208181403.jpg
Old Feb 8, 2018 | 03:01 PM
  #72
Ratical's Avatar
Build is looking awesome!
Yeah, laying on a cold floor isn't as much fun as it used to be when I was 20-30 years younger. Lol
Old Feb 20, 2018 | 07:12 PM
  #73
forcd ind's Avatar
Making a little progress everyday, brake lines all run, might add some juice tomorrow and look for leaks. Intercooler is all plumbed, wastegate pipe installed, 4" downpipe is down to the trans. This time I angled it away from the engine a little so I could get to #8 plug easier. Rebuilt my 80E trans, just waiting to dyno it at my buddies shop. Kind of nice to know if it works before install. Still have to order fuel lines, fittings, prob finish up that next week, if not b4. Pretty much leaves me all March just to wire it up, install the front clip, hopefully fire it up.
Attached Thumbnails Nova going in under the knife-0210181044.jpg   Nova going in under the knife-0213180849a.jpg   Nova going in under the knife-0219181323.jpg   Nova going in under the knife-0220181931.jpg
Old Feb 20, 2018 | 08:12 PM
  #74
Bad Apache's Avatar
Looking good and coming along well. Nice work!
Old Feb 20, 2018 | 10:04 PM
  #75
slocaddy's Avatar
Push loc for the win!
Your using a dual pass radiator?
Old Feb 21, 2018 | 06:12 AM
  #76
forcd ind's Avatar
Its the Griffin LS swap radiator, dual pass-I used it on another swap and it worked good. Using F body fans, stage them thru the Holley HP.
Old Feb 21, 2018 | 08:56 AM
  #77
Suncc49's Avatar
LOL, I know you... we emailed when I was selling my old Nova build and beginning my turbo ls swap.
Why did you only keep that car 6 months?!
Forcd - Build is clean and looking awesome
Old Feb 21, 2018 | 11:20 AM
  #78
blu72nova's Avatar
Making really good progress. Do you know which specific hose you used for the lower radiator hose? Part number or anything like that? Thanks
Old Feb 21, 2018 | 12:11 PM
  #79
408GT's Avatar
I would try to limit as many 90* and 180* fittings in the system as possible. Each of those fittings are adding restriction to the system (and cost).
Old Feb 21, 2018 | 12:19 PM
  #80
ryeguy2006a's Avatar
Sorry I missed it, but what log manifold are you using?
