What intake is BEST for a LS turbo motor?
Old 11-14-2017, 04:01 AM
FirstClassAutomarine's Avatar
Default What intake is BEST for a LS turbo motor?
LS1, 255 Trick Flow heads, Callies rotation assembly, 94mm Garrett, 6 speed manual 1500hp plus at rear wheels.
Old 11-14-2017, 04:28 AM
Game ova's Avatar
Weiand team G.
Old 11-14-2017, 04:58 AM
My 6.0 is fuel injected.
Old 11-14-2017, 05:03 AM
Game ova's Avatar
Oh...a 6.0 Ls1, Not really sure what would even fit that. But I must say, that's a pretty wild deal you have there. A 6 0 Ls1 that makes 1500rwhp.
Old 11-14-2017, 06:30 AM
Restricted User
JoeNova's Avatar
What intake would you recommend for my 1501whp 427 LS1?
Old 11-14-2017, 07:12 AM
etijsma's Avatar
g1pro look real nice.
Old 11-14-2017, 07:44 AM
asubennett's Avatar
Plazmaman, Shaun's alloy, Frankenstein has a new billet piece as well.
CID with an All Pro elbow would be a good choice as well. Those are best of the best.
Old 11-14-2017, 07:54 AM
Restricted User
JoeNova's Avatar
Given the circumstances, that's the best possible comeback anyone could have possibly given me LOL.
Old 11-14-2017, 08:43 AM
AnotherWs6's Avatar
A stock LS1 manifold. They are cheap, fairly tough and the intake flow doesn't matter because with that much turbo anything will work. That's what I'm gonna go with on my 454 LS1 Turbo project.
Old 11-14-2017, 09:14 AM
transam69230's Avatar
I assume it was carb'ed and you switched it over?
Old 11-14-2017, 09:26 AM
dburt86's Avatar
holy ****, im on the wrong forum. I dont even have a proper LS. Just a damn LQ4.
You guys are tools.
Old 11-14-2017, 09:43 AM
pantera_efi's Avatar
Default LS-1/2 ITB's Bellmouth
Hi First Class, the best turbo intake for spool/torque/HP is my 65mm ITB intake manifold. This is due to the large "bell-mouth" inlet and large tapered runner.
The runner is offset in the direction to enhance Swirl. The pressure waves inside the runner will be stronger than N/A due to the MORE DENSE runner air. (15 .lbs = 1.5 Density Ratio)
The fuel injector is placed HIGH in the runner, over top of the butterfly.
This injection point, when fuel spray occurs, will "shrink" or cool the air as it travels down the port by removing latent heat making the air more dense.
The eight butterflies being close to the inlet valve, when throttled, keep out exhaust gases stopping them from entering the other cylinders as is with a common plenum. This effect allows much faster Spool.
I have testimonials if asked ?
Lance
File Type: pdf
Old 11-14-2017, 10:55 AM
89BANDIT's Avatar
Never thought an Aluminum SBE LS1 could stay together with that Terbo at 1500+HP???
Maybe it's Stroked to 540 cubes?
Old 11-14-2017, 11:01 AM
Lawhead's Avatar
Says Callies rotating assembly
Old 11-14-2017, 11:15 AM
Game ova's Avatar
Weiand team G.
Old 11-14-2017, 11:20 AM
BudRacing's Avatar
If the 6.0 is making 1500hp, I'd say it's already got the right intake on it.
Old 11-14-2017, 11:40 AM
Floader's Avatar
Your right there, and that would be intake that somehow holds the heads on the block
Old 11-14-2017, 01:10 PM
AnotherWs6's Avatar
It's not 1,500 rwhp guys, it's 1,500 PLUS rwhp. We could be talking maybe 1,700. Through a six speed. Seems like if you know how to get 1,500 + out of a 6.0 and know how to make a 6speed live behind it you should already know a lil' somethin about intakes.
You gonna upgrade that rear? The stock 10 bolt probably wont live to long behind that kind of power.
Also, I think SLP sold a bolt in roll bar, it's something that you may want to consider at these power levels.
Old 11-14-2017, 01:24 PM
Floader's Avatar
Just so we are all on the same page. Can you get that SLP roll bar in Chrome? I mean we are talking about the BEST stuff here.
Old 11-14-2017, 02:43 PM
89BANDIT's Avatar
GT40 Intake, with a B-cam. Would be my choice for this application. Maybe with some aluminum 113 Heads. Those are the L98 HO heads for the C4 Vettes with the TreeFiddies! That would be a killer combo. This is the combo I run on my V-Tec! I run 3.98 in the 1/4!
This bad Mamba Jamma got 3 sec's off my times,
Quick Reply: What intake is BEST for a LS turbo motor?
