Turbo Oil Line Return ?
The pump is really designed to help with low mounted turbos to drain better. Asking it to push through constant resistance pressure from oil sitting in the pan is going to wear on the pump and reduce its effectiveness.
But ideally it would be above the level of oil in the pan. Although with engine running and oil circulating, it may not be far off.
As for the drain. I noted on my oil pan, the oil sits at or above the oil drain. That is because the capacity of my oil system is large (some long oil relocation lines that drain back into the pan cause oil to sit higher than it should). This isn't an issue for the engine when it is running because the pan level will always (should be) lower when the engine is running. So my advice here is that as long as the running engine's oil level is below the drain it should be ok.
And last, the drain location matters, i.e. any oil whipping/flurry/spraying caused by the crankshaft spinning is going to screw with the draining oil. This is why you want a baffled location, so that it can drain without having interference from the spinning/high speed crankshaft/etc... In my pan, there is a trap-door with a hinge that only swings one way (for cornering, I guess) which effectively baffles the oil return from any flurry/whipping action.
Imagine trying to drain and right at the drain you have a blender going... It wont help.
Thanks again!
