Procharger setup and info needed!!
Old Nov 27, 2017 | 06:20 PM
Baderic03's Avatar
Default Procharger setup and info needed!!
so I have a new build in the works and wanna go Procharger in my fox with a LQ9/4 depends what I come across. I plan on doin cam,springs,push rods,and a ls2 intake and TB. Going E85 and looking to be in the 8-900rwhp range. Will the new D1X do it? I can’t find many setups and none with the new D1x this will also have a glide behind it.
thanks.
Old Nov 27, 2017 | 06:41 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Welcome aboard! Yes the D-1X will get you into the 800 to 900 rwhp range. I'd go with the F-1A though, as it has a 5.40/1 gear ratio instead of the 4.10/1 in the D-1X. This will give you better belt wrap with an F-1A as it will end up with a larger pulley on it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Nov 27, 2017 | 06:49 PM
Baderic03's Avatar
Ok great to know. Thanks. I don’t see anyone doing ProCharger’s. Everyone is doin turbos and I want my ac on a street car/play car.
Old Nov 27, 2017 | 07:47 PM
LS1Tech Sponsor
https://www.procharger.com/blog/now-...-units-results
You're welcome. The info here is about the D-1X. Bob
__________________
Old Nov 27, 2017 | 07:51 PM
Baderic03's Avatar
great thanks I read that. But that was through a stick. Auto act different looks like the F1A and 8rib setup should do me fine at like 16-18#s for my goals.
Old Nov 27, 2017 | 07:53 PM
LS1Tech Sponsor
I had a 408 with an F-1A in my 99 Z28 that had a glide. We were seeing 18 to 20 psi with it. Bob
__________________
Old Nov 27, 2017 | 08:05 PM
Baderic03's Avatar
What power.
Old Nov 27, 2017 | 08:08 PM
LS1Tech Sponsor
What power.
With the glide and a 5000 stall converter that we were having problems driving through, we never got good numbers. The 3500lb Camaro ran a 9.12 at a low 146 mph, driving with the converter slipping so badly you couldn't hear it shift. Bob
__________________
Old Nov 27, 2017 | 08:14 PM
Baderic03's Avatar
that at sucks Ky car should be like 2800 area. So planning like 4200 stall converter area since it’s still a street car and a set of 3.73s I don’t know how much these motor will like to be shifted at 7200 with a blower.
Old Nov 27, 2017 | 08:17 PM
LS1Tech Sponsor
7200 with a blower wouldn't be a problem with the right pulley for the rpm. Bob
__________________
Old Nov 27, 2017 | 08:24 PM
Baderic03's Avatar
Ok I know my turbo car I shifted it at 6800 with a stock bottom end but if I can go 7200 then I’ll shift it at 7200 be nice let her eat.
